Question about Whirlpool Duet GHW9150P Front Load Washer
HOW TO REPLACE WHIRLPOOL WASHING MACHINE VALVE MAGNET for AWO/D8500
AWO/D 8500 8KG
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Do not attempt to just replace valve components this is not a proper repair, just replace the complete inlet valve
Posted on Jan 02, 2015
SOURCE: washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Posted on Nov 23, 2008
  • 86 Answers
SOURCE: cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Posted on Feb 27, 2009
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
SOURCE: how to reset service ligth
whirlpool awdo/d 4505 flashing service light
Posted on Feb 03, 2011
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Feb 22, 2012 | Whirlpool Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Washing Machines
WHIRLPOOL AWO/D 8500 WASHING MACHINE DOES NOT PUSH THE WATER THE OUTSIDE OF IT
WHIRLPOOL AWO/D 8500 WASHING MACHINE DOES NOT pullTHE WATER THE inSIDE OF IT
Feb 08, 2011 | Whirlpool Washing Machines
I have a whirlpool awo 3751 washing machine when i close the door set the program press the start button the machine appears to start and the time reduces but there is no water going to the machine i think...
You most probably have a faulty water inlet valve...Not an uncommon problem..They can sound ok, but when you check the detergent drawer there will only be a trickle..Replace the inlet valve...Good luck...Nomess
May 20, 2010 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
101 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
