What can I do when L.G. says that there is a safety feature to PREVENT the unit from working when it is over 115 degrees outside? I've gone around and around for two years with LG. My warranty is vali
I did everything right. I had the repair guy out several times( mostly to satisfy LG), and he reported directly to them. Eventually, after months and months of going back and forth, I got a final decision on my case! It was the following: The model that I have has a built in safety feature that prevents the unit from turning on if the outside temperature exceeds 115f. I was flabberghasted! I live in Yuma, Arizona. It's ALWAYS over 115 outside!(between May and October) My warranty and extra warranty are valid until 2016, so if there's anything you could do, I would appreciate it.
    Problem Solver:
  • 14 Answers
The reason for the temp safety is to save the unit during excessive temperatures. the Freon inside builds to an excessive high pressure and will harm itself by altering to acid or too high of pressure. I would do what I could to shade the unit and keep it cooler some how. keep ventilated but shaded.
Posted on Nov 20, 2014
Testimonial: "if that is the case they shouldn't sell the unit here, or at least be required to tell me BEFORE I spend a thousand dollars on something that CAN'T work!"
hotuna
  • 288 Answers
SOURCE: Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Posted on Dec 04, 2007
  • 400 Answers
SOURCE: Fuse plug in LG window a/c unit is shorted out.
Replace with a standard plug. If this trips any circuit breaker you could have a compressor or capacitor problem.
Posted on Jul 02, 2009
  • 84 Answers
SOURCE: I have an older Goodman CKB 18-1
FOR QUESTION 1: They do run independantly. What will happen when your compressor is running but your outdoor fan does not, the pressures in the system will go really high and compressor will overload. That outdoor fan is used to disipate all the heat that is transferred from the inside to the outdoor unit.
FOR QUESTION 2: If you hear humming it can be 2 things. FIrst one is that that capacitor went bad. Dependiing if its a dual run capacitor(which helps both compressor and fan motor) or they both have individual capacitors. The second would be a bad fan motor. OPen your service panel outside to the AC. Find your capacitor for you fan motor. if there are 2 , locate the one that goes to your fan motor. Check it out(if its blown physically youll will notice it like really bubbled, like swollen) then change itout. Or you will have a dual run capacitor that runs both compressor and fan motor. It will have the terminals marked (Fan, Common, Herm) Bsically check your capacitor mfd(micro fared rating, it will say on the capacitor what its rated) Get a multi meter and put in the "MFD' selection. Before you check any capacitor you have to discharge the the voltage charge it has. Use an insulated handle screwdriver and just place the metel part across the capacitor leads. Basicall short them out. Then proceed with checks...hope this helps( remember to always pull the disconnect out from the box outside to cut power)
Posted on Jul 30, 2009
james3751
  • 614 Answers
SOURCE: My Ruud outside condensing unit stops running when
Check condensor coil to see if it is dirty. It is kicking off on high head. Take a water hose and wash the coils this will help. Take the cover off and wash the coils by the compressor those get the dirtiest. TURN OFF POWER FIRST. Russ
Posted on Aug 16, 2009
hvac1960
  • 2133 Answers
SOURCE: I have LG Model lst243h-2
Check your indoor temp sensor defective. Replace it.
Posted on Jan 04, 2011
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
Fc loclked door how do i fix this
If the oven has a clean cycle it might be that someone put it into the clean cycle. This means that it went to over 500 degrees to clean the oven. Let it cool overnight and the door should release. Do not try and force it-you will damage the door locking. This is a safety feature to prevent harm because of over 550 degrees.
Oct 19, 2013 | GE Profile JDP47 Electric Kitchen Range
Our gravity fed shower only goes warm when bath cold water is turned on
If you are using a conventional shower valve of recent manufacture, there is a safety feature to prevent scalding accidents when it is connected to conventional plumbing on a pressurized system. If there is no cold water pressure against the valve, it shuts off the hot water completely. It is called a pressure balancing valve by most manufacturers.
In other words- it is supposed to do that.
There are ways to bypass the valve, but you may want to keep that feature if your storage temp is capable of temps above 110 degrees F or 49 degrees C.
Dec 14, 2011 | Home
Good Morning, I have an ESE18HRA air conditioner in an investment unit that I purchased recently. Recently the tenants wanted to heat the unit but around 10 minutes after turning the ac on the defrost...
That sounds like a safety feature. Better units protect themselves by shutting off if the outside temperature is not warm enough to turn the freon into a gas properly.
Running an A/C in the winter could cause liquid freon and thick oil to go where only gas should be and lock the compressor.
May 22, 2011 | Heating & Cooling
I am working on a M # GPG13420901AB. This is a 3.5 ton package unit that replaced a 3 ton package unit on 1700sq/ft single level home. Old unit was working fine but was replaced when the home was...
It sounds like you are low on charge. I think you have a thermostatic expansion valve and you need to check the subcooling, you should have 12 to 15 degrees at 95. At 95 degrees your head should be about 280# for a 12 or 13 SEER unit or higher depending on the effeciency. At 78 to 80 degrees indoor depending on the humidity, that is normal. The valve will open to try to fully feed your indoor coil and it sounds like your head pressure is to low to force enough refrigerant thru the coil.
Aug 16, 2010 | Goodman Heating & Cooling
My heat pump is frozen up today and it is 60 degrees outside and I have my heat set to 66 degrees. Is this normal?
You post is not clear as to where the freeze-up is occurring. I'm going to assume the outdoor unit is frozen up.
Heat Pumps don't generally freeze up at 60 degrees. If the ice around the unit has an uneven pattern (for example a thick spot around the center or at the very bottom) could indicate a low refrigerant charge. If the ice is even throughout, it may be one of the following:
*Sticking Contactor*.....turn the system off at your thermostat and check to make sure the unit outside shut off. If it doesn't turn off, it is likely to be the contactor.
*Failed Defrost Thermostat*.....if the defrost thermostat fails "open", the system will never go into defrost.
*Failed Defrost Control Board*......this could also prevent the system from going into defrost
*Failed Reversing Valve*........put your system in COOL mode and check to see if it will blow cold air inside approx 16 - 22 degF lower than room temperature.
*Failed/Failing Condensor Fan Motor*.......ensure the condenser fan motor is running during heat and cool modes. The condensor fan motor will not run in OFF/Satisfied Mode or in Defrost Mode.
I hope this helps. Good Luck! :-)
Mar 05, 2010 | Heating & Cooling
Jets stuf off on their own after about 20 - 30 minutes
This is normal for jets on hot tubs/whirlpools for the jets to shut off after 20 minutes. This is a safety feature to prevent overheating of the water. When jets are running, the hot tubs are constantly heating and can elevate to dangerously high temperatures excess of 110 degrees causing scalds that you would not even know are happening. Your body temperature acclimates to the climbing temps and you dont realize it is that hot. It also helps prevent you from falling asleep and not paying attention to the temps in the tubs. Sorry, but I think you are going to have to restart the jets after each cycle. It is a safety feature that can't be bypassed or circumvented. Good luck and happy tubbing
Dave K
Aug 29, 2009 | Home
After a cooling cycle, when the thermostat call for more cooling, it take up to 5 minutes after the air handler starts for the compressor motor to restart. The top fan operates on the outside unit, but...
No, this cycle cannot be shortened due to the simple fact that this feature is in place to protect your system. Even if it could be, I wouldn't recommend it.
Mat
Jul 17, 2009 | Coleman Heating & Cooling
Air conditioner is not cooling house. Seems to be blowing very little cool air through floor vents. It was 115 degrees today! Do I need to call a repairman?
At 115°F it is very critical that the condenser on the outside unit is perfectly clean and the fan operating. Try to shield the outside unit from direct rays of the sun. At 115° you could be reaching what is called critical temperature for the refrigerant. Yes, have it checked by a qualified service technician.
Jun 19, 2008 | Honeywell Heating & Cooling
Need a replacement thru the wall ac unit for model ajch10acm1, 115 v, 15 amp 9600 btu.
Measure the cabinet dimensions. then best place to check for replacement is Home Depot ,Lowe's, sometimes Sams Club, B.J.'s or Cosco these places buy in large volume and are hard to beat when it comes to price. The 115 volt units go up to 12,000 BTU. which is one ton. If you hit at the right time of year I,ve seen a/c units around 6,000 btu sold for as low as $69.00.
Shop around most all brands are about the same. Cost is based on the number of bells and whistles you want. The most simple units cost the least also the less that can go wrong. I have found it really hard to find exact demention replacements.
May 16, 2008 | GE Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
