Question about Samsung GALAXY S4
Don't know why I call someone, they can hear me, but I cna't hear them unless put in a speaker or using the headset, please advise.
  • 485 Answers
Hi, it seems your phone has a faulty earpiece, it's an internal component that should be replaced by a technical service center that supports your phone manufacturer.
Posted on Nov 16, 2014
2 Suggested Answers
  • 23 Answers
SOURCE: I am not able to
you can contact the service provider........
Posted on Jul 29, 2011
Jabra headset phone
either the switch is partially shorted or the pin on your headet has a shorted wire in it somewhere..try a new headset first..
Jan 08, 2014 | Cisco Computers & Internet
My sony ericsson zylo. when someone calls me they can hear me but i can't hear them, please help
1. try to switch on the loudspeaker or connect a headset. in case you can hear your partner this way there must be a hardware problem with the phone's smaller speaker. Often as a result of firmly hitting (dropping) the phone.
2. make a test call and try to change the volume during the call. (However, I don't think it can be a problem since power off/on cycle resets the volume to a default value)
Sep 04, 2011 | Sony Ericsson Zylo Cell Phone
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
I know the Peak Power Handling is 100 Watt but if i was to put some more drivers to the amp, or 1 driver what is Total power of amp can i put a 150watt driver or 200watt in place of the 4
I'd recommend against any experimentation with this unit unless you are a somewhat qualified electrical (audio) engineer. You can do some serious damage to an amp or the speakers if you don't understand the implications of modifying the load, especially in a downward direction.
At 100 watts 'peak' with a sub-4" woofer this is a modest speaker system at best and probably has very limited potential improvement.
Read: http://en.wikipedia.org/wiki/Audio_power
Aug 04, 2011 | Eltax Planos 5.1 System
I have no sound from one channel. I have swapped speaker leads (sound just swops with the speaker). I have taken lead out of CD player and touched ends of leads for "earth hum". Only get hum on...
If the sound stays with the speaker, then the problem is with the speaker not the receiver (unless I misunderstand). You state that changing the speakers that the sound stays with the speaker. This means that both channels are producing sound, it is the speaker which is defective. You can verify this by using a 9V battery. Quickly touch the leads from the speakers to the battery. You should hear a pop or click. If the speaker is defecive, you won't hear anything.
Let us know what happens.
Dan
May 08, 2011 | NAD C350 2-Channel Amplifier
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
Computer headset problems
It sounds like something in the control panel on your computer, Go into the sound settings and pick your device.
Below is the link for Explorer 300 Series User's Guide.
Plantronics Explorer 300 Series User's Guide
Good luck from Headsets Direct!
Jan 17, 2009 | Plantronics Explorer 330 Headset
Treo 600 can't hear without headset
Try blowing hard on the spot where the headset plugs in. I have this same issue on my treo and a good burst of air will at times bring back the speaker/microphone.
Nov 24, 2007 | Palm Treo 600 Handheld
Samsung GALAXY S4 Logo
76 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
