Question about Refrigerators
A portable table top Icemaker by Gearsmith ?
Table top portable Ice Maker
watugot
  • 290 Answers
SOURCE: icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
  • 489 Answers
SOURCE: LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
Posted on Jun 08, 2008
gtaplytmpt
  • 90 Answers
SOURCE: icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Posted on Jan 02, 2009
SOURCE: ice maker makes very little ice
my under the counter ice machine makes very little ice. we just paid $600 to have a repairman put a new motor in it (although I don't think that was ever the problem) because it would always run, it was just not making any volume of ice. now it's been fixed and the repairman brought it back under th counter yesterday and it's STILL not making more than maybe 1 cup of ice in over 24 hours. I can hear the water running when Iopen it, but just don't get the bin full of ice like it used to get. HELP!!
Posted on Apr 09, 2009
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Jan 07, 2016 | Emerson Refrigerators
Nostalgia Electrics Ice Maker Troubleshooting
My Nostalgia Ice maker shows low water, but there is water up to the fill line.
Mar 10, 2014 | Nostalgia Electrics RIC-100 Retro Series...
Ice maker not hooked up (on purpose). The ice
Sounds like you are not going to use the automatic icemaker, so I would remove the whole icemaker unit which will include disconnecting the wire harness behind the icemaker which will shut off power to the icemaker and will also give you more storage room in your freezer compartment.This will not harm the refrigerator or the icemaker, you could also disconnect the waterline if you want.Please note that this solution applies to the top freezer,and bottom freezer style refrigerators only thatt DO NOT have dispensers through the door. Good luck !
Dec 02, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Magic chef MCIM30TS table top ice maker shovel breaks
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Nov 21, 2008 | Eastern Tabletop 7002 Stainless Steel 24...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
