Slowly motor running in washing mode position,what's the problem?
  • 25 Answers
Loose belt or warn out belt
Posted on Nov 26, 2014
Fisher and Paykel Washing Machine model mw512
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself.
when it's filling with water, does the bowl go around slowly?
Sep 11, 2013 | Fisher and Paykel Washing Machines
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
Hi, I have SW1ASP Samsung 6 kg washing machine. Its washing but not spinning. its try to spin and motor try to pushing to spin but it spin slight and stop. When i jiggle the machine while it try to spin...
1) may be your spinning cloth load over.
2) Check inside the container (space of wall & spin tube) cloth may be inside.
3) Door stopper (Brake) position not correct.
Actually the spin motor starting slowly first.
Mar 26, 2011 | Washing Machines
My oasis kenmore elite keeps flashing f 50
The machine control through the rotor position sensor (RPS) cannot detect the motor running. The rotor is stuck, the rotor position sensor is faulty, or the machine control is malfunctioning. Open the lid and turn the drum manually. If it turns freely, activate the Manual Diagnostic Mode Test to check the functionality of the rotor position sensor and the machine control. If it doesn't turn freely, let us know to guide you in troubleshooting and repairing it.
The machine should be in standby mode when activating diagnostic test mode. That is, the machine is plugged in will all indicators off, or with only the Clothes Clean indicator on.
Choose any single button except Start, Stop, and Power. Press and hold the chosen button for 3 seconds and release it for 3 seconds; press it again for another 3 seconds and release it for another 3 seconds; press the same button again for another 3 seconds and release it (press, release, press, release, press; 3 seconds each).
The indicators will all light up for 5 seconds with 88 displayed in the Estimated Time Remaining display if the test mode has been successfully entered.
Repeat the procedure if the test mode is not activated. You may choose another button. Let us know if it cannot be activated after multiple attempts failed.
Press the same button chosen above before the indicators turn off (5 seconds). A single beep sounds and the two-digit console ID number is displayed. After 3 seconds the display is cleared (00) and the Add a Garment indicator flashes.
Open the lid and rotate the basket manually. The Wash, Rinse, and Spin status indicators should toggle on and off according to the rotation of the basket.
Press and release the 2nd Rinse button to lock the lid and the lid lock indicator turns on. Press and release the Rinse Speed button. The basket should spin slowly; pressing it again will raise the spin speed. The motor turns off and the basket stops the fourth time the Rinse Speed button is pressed.
With the basket stopped, press the Soil Level button to activate the Gentle wash action. Press it again to activate the Normal wash action. Press it again to activate the Heavy wash action. Press it again to turn off the motor and stop the basket.
Let us know the result of the test for us to guide you in troubleshooting the problem and eventually repair it.
Feb 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer will fill up and then nothing almost sounds like the timer
I assume the timer is mechanical instead of electronic--try turning the dial slowly through the full cycle positions. You should get motor operation at some points along the dial. If the motor never reacts, look for a circuit breaker button on the motor near it's wiring entry. With the power plug out, try turning the motor shaft to make sure it is not bound up. If the motor does run at points, then probably the clock motor on the timer is bound up.
Aug 02, 2009 | Washing Machines
The rear wiper on my '99 model exped isnt working ,ford global says its the motor and it will cost me P13k . any one who can help me find a mechanic do some repair on this?
what is P13K?
check the fuse first. dealer can hook up NGS Tester and get fault codes to see what is wrong.
Principles of Operation
NOTE: The generic electronic module (GEM) will not activate the rear wiper system if either the liftgate or the liftgate glass is ajar. If either the liftgate or the liftgate glass becomes ajar while the rear wiper is in operation, the GEM will park the rear wiper motor.
There are two distinct modes of wiper operation:
  • Off Mode: In this mode, there is no rear wiper activity, and the wiper motor will be in the PARK position.
  • Interval Mode: This mode is selected when the rear wiper switch is in either the Interval 1 or 2 position. When this mode is selected, the rear wiper motor is driven up onto the glass by activating the rear wiper UP relay. When the wiper motor HIGH/LOW/PARK position input reaches the high position, the UP relay is deactivated and the DOWN relay is activated to reverse the wiper motor direction. When the wiper motor reaches the LOW position, as determined by the HIGH/LOW/PARK position input, the GEM deactivates the DOWN relay and will begin a new wiper cycle 1 to 10 seconds later, depending on the interval position selected.
To engage the rear window washer, rotate the rear window washer selector downward to the WASH position. The rear window wiper will run as long as the WASH position is selected. When the rear window washer selector returns to the OFF, INT 1 or INT 2 position, the washer will stop immediately, but the rear window wiper will continue for two to three sweeps and then return to its previous mode of operation.
The low washer fluid indicator chime warns that the washer fluid level is low. The low washer fluid indicator chime is a single tone with a duration of one second. The chime will sound when the low washer fluid indicator is initially activated.
The low washer fluid indicator warns that the fluid level in the washer reservoir is low. The low washer fluid indicator will illuminate when the washer fluid level is low and the ignition switch is in the RUN position.
The low washer fluid indicator will deactivate when the washer fluid reservoir is filled and the ignition switch has been cycled from RUN to OFF, then to RUN.
Inspection and Verification
  1. The wiper/washer system is a generic electronic module (GEM) controlled system; refer to Section 419-10 .
  1. Verify the customer concern by operating the wiper/washer system.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Hoses to windshield washer pump
  • Wiper linkage
  • Fuses 6 (5A), 8 (5A), 15 (5A), and 20 (5A)
  • Wiring harness
  • Loose or corroded connector(s)
  • Relays
  • Motors
  • Multifunction switch
  • Washer fluid level switch
  • The wipers are inoperative — rear
  • Fuses 6 (5A), 8 (5A), 15 (5A), and 20 (5A).
  • Circuitry.
  • GEM.
  • Multifunction switch (wiper/washer switch).
  • Rear wiper up relay.
  • Rear wiper down relay.
  • Rear wiper motor.
May 12, 2009 | 1999 Ford Expedition
Tub spins while in wash cycle
suspect what ge call a mode shifter pull front panel off by sliding putty knife along edge at each side and pressing clips front comes right off look on motor for a flashing green light (washer must be in operation) there are 2 wires in a single plug on motor these run back to transmission area with a volt/ohm meyer unplug and ck between the wires for continuity should be roughly 90 ohms if bad will not show any continuity
Oct 08, 2008 | GE WWSR3090TWW
Front load drive motor on Kenmore washer will only turn the drum in a counter clockwise direction an there is no fast spin
you could have choosen the gentle care mode or delicate mode where in it would only run in one direction and would spin slowly.
tnx 4 using fixya,
drcool
Jul 28, 2008 | Whirlpool Washing Machines
Maytag MAH21 - main motor won't run
Please check microswitch block door/ Best result change this microswitch on the new. If terminal is shot - longered on wire.
Rashid Moscow (arashid@yandex.ru)
Dec 19, 2007 | Maytag MAH21PDD Commercial Front-Load...
My model actually is 417.99570140
Gearbox fault, or a moter running in the wrong direction due to faulty motor or timer/programmer. Regards Engineer
Jan 12, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
