What is code for TCL Model TAC-15CHS/R air conditioner
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
028,022. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Nov 16, 2014
I have a TCL TAC-09CP/C portable air conditioner, working, clean. Everything looks fine but it does not cool. I was wandering If I need to refill the cooling gas. Is it possible? What can I do?
Find out if the thermostat is turning the compressor on first. The compressor has a capacitor that can go bad. Freon leak is possible but unlikely unless the coils in the back have been damaged by something sharp.
Sep 14, 2017 | Heating & Cooling
What does Ft mean on a TCL portable air conditioner
FI - Failure1
This message could appear if the water filter is particularly clogged. See section: "Re-placing the limescale filter".
If the filter has been replaced recently, contact your local authorised service centre.
http://airmaster.net/delonghi-portable-air-conditioner-troubleshooting/
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
Jan 06, 2017 | Heating & Cooling
How do I refill water in a portable air conditioner. TCL TAC-09CP/C
If it's an air conditioner it probably needs freon and not water
Dec 19, 2015 | Miscellaneous
Air conditioner TCL TAC-12CHS/G not cooling
you could have ither an electronic or lectrical problem, your electronic board in the inside unit or a bad capacitor for example not letting the compressor to run. call a service man or some thng
Jan 26, 2014 | Heating & Cooling
I have ac tcl model tac-42cf is not working and have error code in the display,how i can fix this trouble for this error?
I have the same problem..but i fixed that. if u have the same type with mine; TCL split type ac, TAC-42CF/A,380V 3N~. Then u can try this.
1. open indoor panel.
2. find 2 cable in socket pcb that is p11 And P12, u plug p12 on p11,and p11 on p12.
3. if not solved, try the same just like point 2 on power suply 3phase cable R.S.T try S to R, or else.
4. hopefully ur problem solved.
Aug 14, 2012 | Cars & Trucks
My TCL TAC-12CPA air con display panel show "PF" and it would not be able to start.
PF-Power failure in pcb board. Check power to indoor unit and then to PCB. If no power, repair your PCB>
Jan 02, 2011 | Heating & Cooling
TCL TAC-12CS/J displays 1 and beeps 4 times then turns off.
Check your indoor fan motor mechanism is locked. Replace bearing, if u can or replace motor. Helpful?
Dec 20, 2010 | Heating & Cooling
I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Feb 06, 2010 | Heating & Cooling
TCL air conditioner wiring
John what is the problem ? My 18CHS gave me problems but are now fixed. Maybe I can help
Dec 18, 2009 | Heating & Cooling
TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 14, 2009 | Heating & Cooling
Televison & Video Logo
Top Televison & Video Experts
