Question about Garden
My neither my heat or air-conditioning is not working on my 2005 John Deere 5525 Tractor.
  • 114 Answers
Ac may need cleaned out--all that is accessed thru the cab--blow out the radiator
Posted on Nov 20, 2014
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
I need a wiring diagram for the air conditioner system on a 4440 john deere tractor. i am having trouble locating the source of power for the air conditioner compressor.
No luck finding a wiring diagram. Only thing was a complete factory service manual here - $87
JOHN DEERE 4440 TRACTOR SERVICE MANUAL TECHNICAL REPAIR SHOP NEW PRIORITY...
And the Clymer manual here - $35
John Deere Model 2510 4840 Tractor Service Repair Manual
If I were going to try to keep the 4440 going for as long as possible I'd go with the factory manual.
Sep 25, 2017 | John Deere Garden
5525 john deere tractor keeps buring ignition switch
First you will have to check for a short , next i would check the ballast resistor. if the points also burn chance this is a problem.
If you have the wiring diagram check to make sure every thing is wired correctly Good Luck
Dec 08, 2015 | John Deere Garden
How to replace the ignition switch on a 5525 john deere
Here's the link and I'm sure you will get the solution of your problem.
5525 john deere
Sep 21, 2015 | John Deere Garden
What could be causing the fuse f1 to blown when turns the switch on the john Deere 5525 tractor?
Probably......Your starter motor is jammed up or the solenoid. Oil and tap hammer the starter motor and gear to the flywheel to see if you can free it up. Otherwise disassemble the starter from the housing and see if the motor will spin when you put 12V to it
Mar 04, 2015 | John Deere Garden
4455 John Deere Tractor
get the radiator boiled and cleaned., we had the same problem with our 4960 that we couldnt figure out why it was overheating we did that now never have no troubles
Mar 22, 2012 | Ertl 164 John Deere 4455 Tractor
My neighbor has a John Deere lawn tractor. While he is operating the mower it is regularly cutting out to an idle then reving up. This goes on the entire time he is mowing on a 39 second cycle. I would...
first make sure the air filter is clean, next check the fuel tank and clean the gas cap, it has to have the vent hole working or this cutting out will happen, make sure the spark plug isn't fouled or gaped, Look here for Plug conditions http://www.kichline.com/chuck/fixit/mowers/sparkplug.html
Jun 18, 2011 | John Deere 420,1020,2010,2020,2510,2520...
MY CARBURETOR IS WEAR DOWNWHICH I BEEN PUTTING KITS SO SHOULD I BUY A NEW CARBURETOR FOR 2010 GAS MOTOR,it,s a john-deere tractor
Yes it is time to buy a new carberator unless you know someone who can make and install bushings in the trottle plate shaft, and choke shaft. What normally happens over time is the shaft wears into the housing as it is being used which allows ecsessive air into the fuel air mixer which causes inproper run conditions and no matter how much you adjust all the settings you cannot overcome this condition so its either get new bushings made and installed or purchase a new carberator. Hope This Helps Don
Nov 28, 2009 | John Deere 2010 Tractor Basic Carburetor...
Problem with plowing with my john deer 4440 tractor
check you air cleaner and fuel filters if they are dirty it will rob horsepower
Mar 31, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
