Question about HQRP Front Door Master Electric Power Window Switch Driver Side f
How to check electric window switch on 2006 dodge xs
2006 Dodge Grand Caravan All 3 brake lights don't work. Replaced burnt out high center bulb, checked fuse under hood, replaced Stop Light Switch.
Is there power to the stop light switch? You never say any electrical testing was done. Use a 12 volt test light to check this. You can buy one for about $5 from auto parts store.
Sep 20, 2016 | 2006 Dodge Grand Caravan
I have a 2006 Dodge Charger just replace alternator will turn over but won't start
Is there spark , fuel ? Fuel pressure test , test electrical circuit ! Go on youtube an check out some videos on trouble shooting Cranks - no start videos ! How to test fuel pump electrical circuit , COP- coil on plug ignition system testing !
Apr 18, 2016 | 2006 Dodge Charger
Back window was down on dodoge magnum, died while driving and now won't start
well thats just a button replacement main button window switch
and a possibility a ground short out fried battery if you want back window up apply electricity to the window lead and window would go up
Nov 09, 2013 | 2006 Dodge Magnum
Where is the relay switch for power windows in 2006 dodge stratus
There is no relay for the windows, if all windows aren't working, check the fuse (#2). It could also be a faulty windows on/off switch on the drivers side.
Feb 12, 2012 | 2006 Dodge Stratus
The passenger side window on our 2006 Dodge Grand Caravan SXT doesn't work, when the button is pressed
1) Check the fuse to see if it is blown. 2) If you can, try moving the window as you press the button. Sometimes the motor gears get jammed and they just need to get back in step. 3) If this does not work, then the switch or the window motor is blown. Take it to a mechanic to test or use a voltmeter to check electrical continuity
May 13, 2011 | GPS
The back pasenger electric window of my 2006 dodge ram 3500 deisel wont go up.both the switch on the door and the switch on the driver control door dont work. checked the fuse box but found nothing labeled...
hi, there is a relay for the windows. in the fusebox (s) there should be a relay for each window. these relays do fail (open circuit on switch side). the feed POWER side may be shorted. these circuits are hard to find the fault, but check all the door relays. the motor can stick and put heavy current to blow the fuse, if you leave the engine OFF and put the ignition ON press the other window and listen for this relay noise. a click can be heard to pinpoint the location of other relays. once you find these switch relays to determin if these are working and use this to put the rear window back up. gerry
Sep 13, 2010 | 2006 Dodge Ram 3500 Truck
Drivers side window won't roll up
check for power at that window motor plug behind door panel while operating window switch. No power? replace window switch. Have power? replace motor.
Nov 28, 2009 | 2006 Dodge Stratus
Location of master power window switch in 2006 dodge stratus
the window switches in the drivers door is the master switch
Oct 17, 2009 | 2006 Dodge Stratus
HQRP Front Door Master Electric Power Window Switch Driver Side f Logo
Top HQRP Home Experts
Donni Steen
Tom Chichester
Are you a HQRP Home Expert? Answer questions, earn points and help others
