Question about Toshiba Televison & Video
How do i fix my Toshiba tv will not come on
Light red is on the dvd player moves
    Top Expert:
  • Toshiba Master
  • 74,459 Answers
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 16, 2014
4 Suggested Answers
SOURCE: How do I hook up the DVD player to the TV?
Hi, basically you need to put them into their respective slots in the back of the tv. I know this can be frustrating because the slots are all faced downwards, tucked behind this piece. Look at this image, which should be what you are seeing if you're using a Toshiba 26'' 26AV502U, a model similar to yours.
http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9034733&productId=1218010846690&&viewtype=backView&count=0
Look at the four plugs with labeled "Video 1 In." "L Audio" is your white plug, "R" is your red plug(R actually stands for Right [Audio Input]), and Video is your yellow plug. It would be wise to remember this for every Audio/Video cable accepting unit. It makes sense you are putting the cables IN to the tv, hence "Video 1 In."
Now, to tell the tv to read the video input, find and hit the "Input" button on the remote, and it should be one of those options..(there are only a couple to choose from).
Hope these directions worked for you, and enlightened you!
Posted on Jan 13, 2009
  • 23 Answers
SOURCE: Have connected cable (white,
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Posted on Mar 13, 2011
SD Tech
  • 14553 Answers
SOURCE: The screen will not turn on (the red light is not on either), however when i plug in my tv the dvd player starts up, how do i fix the screen?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Posted on Mar 30, 2012
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
MY TOSHIBA DVD PLAYER HAS SUDDENLY STARTED DISPLAYING IN RED ON THE TV SCREEN. THE TV WORKS FINE ON ITS OWN SO SUGGEST THEPROBLEM LIES WITH THE DVD PLAYER.
if this is connected with component wiring (red, green, blue for video) check that all 3 wires from DVD to tv are good it souns like one of those wires might have gone bad or got pulled out or moved by mistake. that would be the best place to start - if this doesnt help please write back with as many details as possible and i will try to give you more help
Mar 29, 2011 | Toshiba SD6100 DVD Player
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
Please few things...
1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
Hope this info will solve your problem.
Thanks.
Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
Player won't open. how do we reset?
my dvd player is stand on the red light when i insert the dvd the dvd will hand after few seconds what is the problem please solved my problem
Jan 04, 2010 | Philips DVP642 DVD Player
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Hooking up this dvd player -- I have audio but no
TRY USING THE RED AS THE YELLOW AND THE YELLOW AS RED, THIS SHOULD MAKE ONE SIDE OF THE AUDIO NOT WORK AND THE VIDEO WORK. REPEAT WITH THE YELLOW/ WHITE. TRY DIFFERENT CORDS. TRY IT ON A DIFFERENT SYSTEM. YOU MAY HAVE KNOCKED SOMETHING LOOSE INSIDE IT.
Nov 16, 2009 | Pioneer DV-343 DVD Player
DRC277a red light only
The red light on my player is on when the unit is off and it is on when in the standby or play mode.
Jan 14, 2009 | RCA DRC277 DVD Player
Televison & Video Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
