Question about Lifetime Toshiba Satellite T115DS1120 Replacement Laptop Power AC Adapter Charger (91812006144)
<!-- from fixya rte -->Black screen...harddrive led not blinking - Lifetime Toshiba Satellite T115DS1120 Replacement Laptop Power AC Adapter Charger (91812006144)
    New Friend:
  • 64 Answers
Well maybe you have problem with AC charger or conector on laptop...try to measure Voltage on AC and if that i good than you need to dissasembly whole laptop and fix or replce AC IN connector.
Regards,
Jovan.
Posted on Dec 11, 2014
Lg tv blink codes
Take the screen off connect power and watch LEDs if any don't flash its LEDs only needed to change faulty strip if they all flash its probably t con boards.
Oct 28, 2017 | LG Televison & Video
Hitachi TV LED screen went black
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 12, 2016 | Hitachi Televison & Video
Acer aspire 5515(laptop) screen is black turns on screen stayscompletly black...no acer logo nothing just a black screen. power button comes up green u can hear the fan and harddrive start up
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Acer Aspire 5100-5033 Notebook
Will power up but black screen with no sound
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 20, 2012 | Sharp LC-C4662U 46 in. TV
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
My laptop will turn on the compac screen comes on then the screen goes black
Alright, does your laptop after the compaq logo come on goes black and is there a blinking scroll or does it say anything afterward? If so, it could be a harddrive failure, you can check this to make sure if it is the harddrive if you can go into the bios menu and see if the harddrive is presented. If it is not, then you probraly have a bad hard drive and it not loading after the "post" test.
Jan 18, 2011 | Compaq Computers & Internet
Black screen and a blinking green led..
Have you tried booting the machine into safe mode? turn off the pc and try inserting a rescue boot disc to see if it will go that route.
Aug 27, 2009 | Samsung SyncMaster 244T Monitor
I got LED lit on but black screen. No harddrive movement or sound
when you power up the computer press F8 key if you can see safe mode and otehr menu then you can do it.
Enter in enable vga mode then change screen resolution 1024*768
Jul 27, 2009 | Acer Aspire 5920-6727 Notebook
Lifetime Toshiba Satellite T115DS1120 Replacement Laptop Power AC Adapter Charger (91812006144) Logo
57 people viewed this question
Top Lifetime Computers & Internet Experts
Paul Bade
GG TECHNOLOGIES
tony wahlman
tony wahlman
Are you a Lifetime Computer and Internet Expert? Answer questions, earn points and help others
