I have a 60" plasma tv that recently has suddenly gotten fuzzy with color distortion. It was turning itself off, so I replaced a couple capacitors on the sub power board and it worked great. A few days later it went fuzzy with color distortion. I have tested the x and y sustains and the Voltages check fine. The fuses are good. Is it possible it could be a capacitor? They all physically look ok? The only thing I haven't done is isolate the control board. But the board has five small green lights that go on when tv is plugged in. One of the green lights went out after this problem occured. Is it telling me there is a short somewhere? Please advise if you can.
    Champion:
  • 209 Answers
Your cannot look at a capacitor and determine by its outside look (unless it obviously looks discolored), if it is truly good.
Posted on Nov 25, 2014
5 Suggested Answers
SOURCE: LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Posted on Oct 21, 2009
SOURCE: Sanyo DP50710 50'' plasma TV turns on power light then turns off/ on on its own. No picture. After checking all fuses and capacitors, we installed rand new power supply board. Still the sa
The set will need to be professionally diagnosed. There could be a # of things causing your problem. Playing the guessing game can get quite expensive.
Posted on Sep 24, 2012
SD Tech
  • 14553 Answers
SOURCE: Lg 50pc55 plasma- has sound but no display??
Quite possible-----replace all bad ones and also if possible the voltages coming out of that board need to be tested---to be honest other than the caps it sounds like a main board issue. The set may have been run too long with the bad caps.
Posted on Dec 08, 2012
gopakumarg43
  • 74634 Answers
SOURCE: I have a 65" lg plasma tv and I recently replaced
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
After replacement of the power board, Va&VS voltages are to be set according to the silk screen; can be located at the display panel, and it is a must for plasma displays.
Posted on Nov 06, 2014
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
I have a 65" lg plasma tv and I recently replaced s few capacitors that were bad and the tv worked beautifully, yesteddy morning I was watching and suddenly the tv went dim and fuzzy like snow but I still...
Nov 06, 2014 | Televison & Video
I have a 46 inch Toshiba plasma tv. It is having a problem where the picture does not come up as soon as I turn on the TV. After about 20 minutes of warming up, the picture appears as normal but during the...
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
Dec 31, 2010 | Toshiba 42HPX95 42 in. Plasma Television
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Pioneer Elite Plasma TV 2-yrs old loses color randomly.
Would need model number to search properly. On some sets a capacitor "C2601" of Y-Drive assembly contacts the audio bracket and it is damaged, can cause a abnormal picture.
Sep 08, 2009 | Pioneer PDP-5070HD 50 in. Plasma...
I have distortion of playing tapes.
Degraded tape, dirty heads (clean with acetone and Q tip but don't get on plastic), dry coupling capacitors.This assumes that the distortion that you refer to is dirty or fuzzy sounding audio.
If a new tape, recorded and played back, sounds ok then your electronics are in good shape. That means your tapes are junk. If cleaning heads takes care of it, well that's pretty obvious. If your capacitors are dried out you will need to bring it in to a repair shop.
Apr 20, 2009 | Audio Players & Recorders
No Color image - B&W image is distorted
it could actually be the cable box itself or there could be corossion on the cable connection outside
Dec 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Funai tv
Open the back cover and check any fuse blow in Y Sustain board or Z Sustain board. If you do find the fuse gone, replace the board. Good luck!
Jan 25, 2008 | Funai F42PDME 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
