LG washing machine model WP 8003 draing slowly during washing,how to rectify.
The drive belt could be slipping or you have a partial blockage in the pump intake/discharge/hoses. Remove from power, remove front or back depending on model. Look at the belt while its draining for any slippage. If that's ok, remove power and inspect/flush out hoses, inspect pump impeller and intakes for clogging, broken or cracked blades etc, replace as needed. Don't overlook the possibility the system its draining into could also be clogged, P trap, etc.
Posted on Nov 16, 2014
MNTECH
  • 1543 Answers
SOURCE: I have an LG washing
Water inlet valve is not sealing off 100%. Replace inlet valve (the part where the hose attached to the machine). didn't find that exact model listed so couldn't give you a part number. Usually LG's have a separate valve for the cold and the hot. If you turn off one valve where hoses connect to household plumbing you should be able to figure out if it is the hot or cold. (most often it is the cold) Leave both valves off when not using washer until fixed. (note: usually on LG washers, if you have unit connected to power and the door closed, if it fills with water as your machine did, the water level switch will trip and automatically pump the water out, even if washer is not in use and the power is "off".)
Posted on Aug 31, 2008
SOURCE: Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
Posted on Mar 12, 2010
  • 311 Answers
SOURCE: LG front loaded washing machine vibrates during
If its on a pedistal then that will raise your center of gravity and cause the unit to be less sturdy during a spin. It could also be due to a weak floor. You may want to try a product called "shake away pads". The probably sell them at like home depot or lowes. They will run you about 40 bucks but they just go under the legs and help absorb some shock. Good luck _MJ_
Posted on Apr 27, 2010
beckeysutton
SOURCE: My LG washing machine is flashing PE
stops washing
Posted on Jul 18, 2010
SOURCE: LG Model WP-9241 Washing Machine - Wash tub ok but
i am getting problem in spin unit pl give us manual of it for repair
Posted on Nov 07, 2010
My lg washing machine model wp 9241 spin lid broken. How and where to find solution for it.
Just buy a new lid for that.. If u dont found means remove and use the drain lid but be careful dont take hardly
Jan 25, 2018 | LG Washing Machines
LG Semi Automatic WP 9220 washing machine water is not draining out what to do
Enter your model number into the self help section of repairclinic.com, you will receive specific trouble shooting info for you appliance.
May 11, 2015 | LG Washing Machines
LG Model WP-9241 Washing Machine - Wash tub spins in only one direction
wash tub spins in only one direction it cannot spin in other direction
Dec 21, 2014 | LG Washing Machines
How to operate LG WP 900 R washing machine
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 04, 2011 | LG Washing Machines
Water is continuously draining from my samsung washing machine . due to this unable to keep washing the clothes .why the problem come & what is the remedial measure to rectify?
Possible that the drain value is half blocked and so is not able to block the water in the tub. Remove the connection to the valve and check if this drains , if so it is confirmed. Remove, clean the dirt and reset. If the leak stays then the valve is faulty.
Also it can be due to partial voltage to the drain valve to keep it open which means that the program controller is faulty. This is confirmed when the drain stops as the connection to valve is taken off.
Jan 13, 2011 | Washing Machines
One or two of my cloth gets stuck and gets torn during washing
slowly run your hand across the baffles ,,slowly or look with a flash light ,,1 of the may have came lose from drum...onthejob
Jan 01, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
