Does anyone have a Rain Master 3414 programming manual? I want a visual of the panel and instructions of each button.
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
Jun 25, 2014 | Home Security
Rain drops instruction manual
Did you know that you can go to Nintendo website & just download any of their manual for games? It might be easier than trying to find somewhere to buy one. I already checked E-Bay & Amazon & none available. So try their website. Hope this helps!
Apr 06, 2014 | Nintendo Rain Drops DS DS
Press power on my philips 32pt6441/37 but power button flashes and no picture
Unfortunately, this is an aging tube type TV. I have repaired many of these when they were still in warranty. In your case you will be repairing the horizontal timing. You will replace a mosfet transistor (location 7404) an 8.2 ohm 2 watt resistor (location 3414) and a driver transformer (location 5402). If you feel you can repair this yourself, I suggest you order the horizontal timing kit with instructions. The number I give you may be obsolete. Don't worry, this number will get you a cross number to work with. Ask for part number 4835 310 57673 for TV chassis L04.1UAA. Thanks for asking and show all hands of support!
Jun 10, 2011 | Philips Televison & Video
We replaced the battery for our Intermatic Rain Tight Outdoor 7 day digital timer MODEL HB71R70 but the instructions to reset the timer have been misplaced. Could you please supply us with step by step...
Hi Maggie.
Intermatic no longer makes HB71 timer, and I cannot find instructions for the timer.
Intermatic website is offline on weekends starting March 2011, but I have searched the site numerous times over past year and they do not post that manual.
However I might be able to piece together steps if you add a comment and include in-focus photo of timer and buttons. Also include anything you can remember about setting the timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
My understanding so far is that this timer has 2 slide buttons, and several push buttons.
Typically slide button timers require both slide buttons to be in one position for setting timer, and another position for programming timer, and another position for operating timer. The complicated steps are why timer has been replaced with newer models with sleeker programming.
If you do not want to bother sending photograph, or working on the problem, then buy another outdoor timer for 20$
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://www.homedepot.com/Electrical-Dimmers-Switches-Timers/h_d1/N-5yc1vZ1xg8Zbm2d/R-100685861/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Apr 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
My pool pump will not swith off, timer working. It will not switch off with the manual lever either
I assume the manual switch is before the timer? If so you need to open the manual switch and see what has happened inside. When you pull the lever the knife switch should open shutting off the pump. Regardless of it the manual switch is in front or behind the timer, pulling the manual switch should disconnect the power. Do a visual inspection and let me know what if going on in there.
Has anyone messed with your electric recently?
Jun 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Print Master Gold 16 compatible with Windows 7?
Compatibility Wizard
1. Open the Program Compatibility Wizard by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jan 03, 2010 | Broderbund Print Master Silver 16.0 for PC
I think I blew a fuse in my 1997 Isuzu Trooper. My ABS light came on as well as my power windows stopped working, and my rear defroster as well as mirrior defroster. This has happended in the past and a...
Locate your fuse box/panel, there should be a listing of all fuses on teh fuse box cover or in the owners manual. I would visually inspect one fuse at a time pulling out and verifying all are good one by one as well as replacing the master fuse. I hope this helps you.
Oct 27, 2009 | 1997 Isuzu Trooper
Jandy Time Master manual
contact jandy tech support they will walk you through it
Jun 02, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
