Question about Dryers
How do I replace plastic window on whirlpool duet steam dryer.
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
SOURCE: Whirlpool Duet Steam Dryer Beeps 3 Times But Does Not Start
Brand new unit - same problem. After an hour of investigating, I found the issue.
You don't actually have to SLAM the door. If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Yay!
Posted on Oct 13, 2009
jsrock516
  • 5911 Answers
SOURCE: My whirlpool dryer (Duet) will not heat. What
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Dec 23, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
Whirlpool duet steam dryer has no heat when drying
Heat generating device is not working, ergo no steam. That part needs replacement. Go to attached site for parts, prices, etc. Search Over 2 1 Million Appliance Parts
Sep 03, 2017 | Whirlpool Dryers
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Duet steam dryer soaking my clothes
You will need to replace the "water valve" on the unit. The solenoid is letting to much water thru. Here is a link to the part to order.
Nov 04, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Slight Gas Smell From Inside Whirlpool Duet Steam Dryer.
Poor pilot - or malfunctioning gas valve.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 20, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Give me a sample whirlpool duet stwasher and dryer serial numbers
What? we dont supply serial numbers sorry! go to whirlpool
Aug 30, 2009 | Washing Machines
Dryers Logo
50 people viewed this question
Top Dryers Experts
