Question about Electrical Supplies
No gas getting to spark plug on proforce powermate 5.5 OHV generator
    Sergeant:
  • 415 Answers
Take the bowl off of the carb. If there is fresh clean gas flowing into the bowl, then the problem is in the carb and it will need to be rebuilt. If not, then there is a blockage between the tank and the carb inlet.
Posted on Nov 26, 2014
5 Suggested Answers
  • 211 Answers
SOURCE: Spark Plug location for Powermate Proforce Generator #PM0102500?
Hi
Try to see where is the had of the engine.
best regards savumihai71
Posted on Feb 12, 2009
  • 80 Answers
I HAVE A WHOLE HOUSE GENERATOR I HAVE TAKEN THE OLD SPARK PLUGS OUT AND DID NOT FIND A GASKET ON THE OLD PLUGS . THE NEW PLUGS HAVE THE GASKET ON THEM . DO I PUT THE NEW PLUGS IN WITH THE GASKET OR DO I FIND ONES WITH OUT THE GASKET.
Posted on Apr 05, 2009
SOURCE: I have a coleman powermate 10hp generator with a
Check you electronic ignition module, replace it.
Posted on Feb 12, 2010
kel1guy2002
  • 3740 Answers
SOURCE: what kind of spark plug
Hi, It uses an NGK: BPR5ES
Kelly
Posted on Aug 26, 2011
Will not start. May need a new spark plug. What size is it?
it should say on the side of the plug very carefully hold the coil wire about a 1/4 inch away from the head or other metal object and crank it and see if it is firing be careful and dont get shocked and make sure to stay away from gas tank and gas fumes and if it sparks chances are it is the plug
and check the oil level because it has a low oil shutdown switch and if it is out of oil or low it wont start
Feb 01, 2011 | Coleman Powermate Proforce 2500 Generator
What size of spark plug do i need for powermate pm0301010
Champion RN14YC, Gap is 0.28/0.31
This is per the owners manual for your specific machine. Hope this helps.
Aug 26, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
I have a proforce 2500 watt generator and it cuts out is this caused by low oil? if I change oil how much does it get?
Low oil doesn't usually make engines cut out. Clean the air filter, change the plug and wire. If this doesn't help then I think you're looking at a carb. problem. Probably just clogged jets & ports. It's very common on small engine carbs. It shouldn't take more than 2 quarts of oil. Probably not even one.
Nov 30, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
No fire to spark plug
one suggestion is:check the black piece that fits into the plug...there might be a wire cut,,..
if u have any further questions email me at sal_kh_sab@yahoo.com
Jul 16, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Dec 22, 2008 | Electrical Supplies
Hi
Dec 22, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Electrical Supplies Logo
37 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
