Question about Kenmore Dishwashers
Kenmore ultra wash dishwasher shuts off after filling
Model2213462
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 644 Answers
Does it really shut off (all lights go out), or does it just not do anything after it fills? If it's the latter, then it is probably a bad main pump motor.
Posted on Jan 17, 2015
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
  • 4 Answers
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
A-OK
  • 10 Answers
SOURCE: Kenmore Ultra Wash Diswasher - wont move past initial cycle
Motor trying to start. blockage in pump, or bad motor!
Posted on Nov 23, 2008
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
Bad triac on control board. Replace control board.
Aug 23, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
My kenmore ultra wash dishwasher wont fill with water i checked the float it seems ok what could be wrong
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 27, 2011 | Kenmore Dishwashers
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Will not drain
can you see the check valve? may have something blocking it closed.
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ULTRA WASH Portable Dishwasher Model 665.1784 leaks
i have had my dishwasher for 10 years never a single problem , i connected it turned it on , it filled with water then it just shut down down won;t do a thing. any ideas?
Sep 27, 2008 | Dishwashers
Dishwashers Logo
51 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
