Question about Ovens
My Westinghouse por667 isnt heating up now, after I baked a cake an hour ago, help!
5 Suggested Answers
milten1
  • 1304 Answers
SOURCE: How I can bake a oblong cake in a
i know this sounds stupid but it works
turn the cake around half way through the cycle
Posted on Oct 08, 2009
Testimonial: "I can't give you a perfect answard but as soon as I try it i will, Thank You very much"
apart4u
  • 213 Answers
SOURCE: After baking cake & 2 roasts, the oven will
fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Posted on Jan 12, 2010
fixyourboard
  • 310 Answers
SOURCE: I am using an old white westinghouse electric oven
Either the temperature sensor has a problem (shorted so the control thinks the oven is colder than the actual temp) or a relay feeding the bake or broil element is welded shut and causing one of the elements to stay on. If the elements are still heating when the "ON" indicator is NOT lit, then you have a welded relay. You need the control board repaired.
Posted on Jun 25, 2010
  • 244 Answers
SOURCE: Whirlpool Self Cleaning Oven - Model
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
Posted on Nov 04, 2010
We have a Westinghouse Continental Electric Range KHB30XKI that was installed in the early 1960's. My mother loves it. Tiny kitchen, slide out burners, space saving. Please help me find elements for...
Do the elements look like the pictures here?
http://www.repairclinic.com/PartDetail/Bake-Element/5300210961/2548 bake element
http://www.repairclinic.com/PartDetail/Bake-Element/5300210911/2183 bake elemenet
http://www.repairclinic.com/PartDetail/Heating-Element/5300210972/1070 bake element
http://www.repairclinic.com/PartDetail/Heating-Element/5300210922/609530 broil element
I hope it is one of the these the first 3 are different bake elements the last one is a broil element that the only pull out elements westinghouse used and i appears all are still available from there on repair clinic
I hope i have helped you to find the element you need,
Gene
Aug 15, 2011 | Ovens
What setting do I use to bake a large cake and also bread? The manual isn't very helpful. PDP790
westinghouse oven, cakes are usually 350 degrees where as bread is anywhere from 4-500 degrees depending on which kind of bread because they are different in weight due to yeast if you have any further questions message me back I await your reply and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future. Oh and btw I had to double check with the wife on this one lol have a great day Thanks Rick
May 08, 2011 | Ovens
Why do cakes sometimes collapse while baking?
helllo dis.... There are many things that can cause cakes to fall in the middle.... Jumping, etc., around the baking area is unlikely to be a problem except with very delicate sponge or angel food cakes. More likely, cakes fall when the crust appears to be done, but the batter is not baked through the middle. An uneven baking temperature is a frequent culprit; check the temperature of your oven with a separate baking thermometer, and be certain that your oven holds a steady heat through the entire baking period. Some older ovens preheat properly, then cycle off and drop the temperature after 15 or 20 minutes, which causes the uncooked portion of the cake to fall.
Less likely but possible problems could be inaccurate proportions of baking powder or baking soda if the cake is made from scratch. This could occur with cake mixes if sour milk or buttermilk is used instead of regular milk; the additional acid in sour milk requires additional baking soda to rise properly. Eggs that are not beaten properly, or perhaps beaten too much for the type of cake being made, might also cause problems. Joe
Mar 12, 2011 | Tecnik Ovens
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
I am using an old white westinghouse electric oven to bake a cake. I selected the right temperature which was between 150 and 160 cel. It started but I could hear the sound of a fan. I kept it on for at...
Jun 25, 2010 | Philips Ovens
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Aug 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Cake texture is course and bottom of cake underbaked
Did you recently change either mixers or brand of any ingredients?
Also, you could be getting heat from only the TOP element. Turn the oven on and look at both. The bottom should be brighter than the top for regular baking.
Mar 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
50 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
