Why the Washing machine doesn't fill water?, I tried to clean the water inlet filter, the drainage filter but still water doesn't go.
  • 25 Answers
Check operation of the water inlet valve, check listening the "click" sound when you start operation of the washer machine, also check if the valve has some type of abnormal sound
Posted on Nov 17, 2014
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
SOURCE: E1 Code - tried fixing it according to manual still won't work
The error code E1 = Water supply error -Not enough water entering the W/M.
Try check water supply line is on and not have any kinked.
Posted on Jun 23, 2008
  • 3 Answers
SOURCE: Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Posted on May 10, 2009
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
My ultima1000, wm 71 says error 10 sometimes and error 11 mid way thru a cycle. The pipes are fine and water is on what could be the problem?
E10 No cold fill detected - washing machine does not fill
  • Check mains water pressure
  • Check inlet hoses for kinks
  • Check inlet filter
  • Check water inlet valve
  • Pressure switch fault
  • Wiring fault
E11 Not hot fill detected - washing machine does not fill
  • Wiring fault
Apr 11, 2016 | Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
When you start it the engine just runs and the machine doesn't fill up with water
Just beyond your filter that you cleaned you will feel some blades, plastic. These blades should turn freely, these are the pump blades, something shd be blocking it, which over flowed from your dirty filter.
Another thing is did your washer not fill with water on starting it? Well take of the power plug from the wall (imprtant before all these jobs!) turn off the washer, turn off the wall valve, unscrew the pipes to see if water flow is gud, check to see if anything is blocking your filters and he washing machine inlet valve. It has a fine filter and is detachable to clean.
Helped?
Mar 10, 2013 | Washing Machines
Washing machine not filling
really sounds like the inlet servos arent working there and might need of replacement
May 06, 2017 | Washing Machines
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Kenmore washer model #110.28882790 is very slow to fill with water. We've checked and cleaned the hose filters. Is there some kind of water sensor? Or hidden filters?
Remove the water line from the INLET valve and start the machine , if there is no proper flow of water then the inlet vavle is not working to open , the filter on the vavle is clogged or the inlet filter is blocked. Also check the voltage on the inlet valve to make sure that the controller unit is outputting correct voltage.
If not replace filter , valve to ensure that the drum get best flow for filling.
Aug 22, 2011 | Kenmore Washing Machines
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
Indesit 1600 WE165 washing machine - filling with water after wash
Doesn't sound like a filter problem to be honest. If the water that's coming in is clean, you're probably looking at a leaky inlet valve. With the machine unplugged from the mains, remove the top, then look for the valves (which are the items that the inlet hoses screw into). One at a time, remove the rubber hoses that connect them to the various bits of the insides of the machine to identify which valve is leaking. New valves are available quite cheaply on the net, and are easy to install. If the machine is filling up with dirty water, it's probably being siphoned back in from the drain. The drain hose mustn't be a tight fit in the standpipe it hooks into and mustn't poke in too far. Also, the standpipe needs to be reasonably tall. Have a look at page 7 of http://imagebank.indesitcompany.co.uk/pdf/service/HBWM81.pdf - it's a manual for a different model, but the drainage requirements will be the same. A.
May 13, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
