I have a manual desktop circa 1940s royal typewriter. Bought it from a professional online who claimed it worked, everything looks good but the carriage and ribbon will not move. Tried messing with the margin buttons but still wont move. Help please!!!
    Scholar:
  • 102 Answers
Hi. The biggest problem with these old typewriters is they sit for long periods of time. The old lube gets gummy and locks everything up. There is a lock that centres the carriage for the cover to close. I worked on these things years ago. If your carriage is not moving, or if you move out to the right and it flys over the draw band or tape is gone. If you a little technical this is how I was taught to clean them. You probably won't be able to remove the platten. The roller the keys hit. Cover it with towel. In a metal can use a little mineral spirit mix with some wd40. 1parts spirit 2 parts WD. Light bristled brush, clean type nest. If you can get it into spray bottle spray areas. You can see. Let it sit overnight to dreaming and dry cover plastic keys as well. Let me know if it helped.
Posted on Feb 10, 2015
  • Jim Spalten
    Jim Spalten Feb 10, 2015
    not dream drain. on old rag towels, dont let it get on wood etc.
  • 453 Answers
Most royal portables have a locking lever to lock the carriage in the center position try looking on the right side near the lower edge of the carriage
Posted on Nov 16, 2014
5 Suggested Answers
SOURCE: Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Posted on Jan 27, 2009
  • 3594 Answers
SOURCE: How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
Posted on Jun 11, 2009
  • 46 Answers
SOURCE: resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Posted on Jun 26, 2009
  • 3594 Answers
SOURCE: IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
Posted on Jul 02, 2009
I have a circa 1940s royal typewriter. Bought it from a professional online who claimed it worked, everything looks good but the carriage and ribbon will not move. Tried messing with the margin buttons but...
Sometimes they had a carriage lock for transporting it. Check for a little lift up lever thingy at the base of the carriage on the bar that goes across from one side to the other. Or just check around for any little levers that hold the carriage in place.
Cheers
Nov 16, 2014 | Office Equipment & Supplies
Royal FP Typewriter's left Magic Margin is not holding. How can I fix it?
There is a spring that holds the margin together locking in place, most likely the spring is gone or the teeth are broken.
Mar 01, 2014 | Royal Typewriter Circa 1957 Fp
I bought a Royal KMM typewriter today (1940s) and it was working fine. I was looking at how to remove the ribbon and now the keys appear to be locked - they won't go up further than halfway. Any...
Look inside to see if any of the metal keys is not level with the others. Sometimes two key rods will go up at the same time and lock together. Otherwise, there is a sort of "stem" that holds the the bottoms of the metal keys in position. You might try cleaning out any debris and putting on a small amount of sewing machine oil.
Oct 29, 2013 | Royal Office Equipment & Supplies
One of the linkage bars for the type bar is missing on my Royal KMM Typewriter
Depending on the size of the holes in the type bar you can make one from a thick paper clip or swap one from a little used key like ; or 1 (you can use lower case L) This isn't a perm. repair.
DickyO
May 23, 2012 | Royal Office Equipment & Supplies
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
I am looking for an instruction manual for a Royal rt 6100 typewriter
are you still looking for this instruction manual? my mother has this version typewriter and yes, the manual is still in the box. perhaps I can copy/scan or post it online for you somehow?
May 14, 2010 | Computers & Internet
How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
Dec 15, 2009 | Royal Office Equipment & Supplies
Apr 09, 2008 | Office Equipment & Supplies
104 people viewed this question
k24674
