Question about Car Audio & Video
I just put in my new pioneer radio and it won't play sound. I have went back and checked the wiring and still nothing. So I went back a third time and checked them and the plunged every back in and it said AMP ERROR. What do I do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You may need to check your speakers for any shorts and/or grounds. Also, make sure the speakers are not common grounded. What kind of vehicle did you install the radio?
Posted on Nov 25, 2014
SOURCE: Pioneer DEH-9600: No power to rear screen
bad ribbon cable
Posted on Mar 25, 2008
merle840
  • 113 Answers
SOURCE: my pioneer deh-1900 mp will not turn on
did you use a wire harness adapter or did you connect the wires from the radio directly to the wires in the car? do you have a computer safe test light or a digital vom meter? do not use a conventional test light in this car or an analogue meter to check for power
Posted on Apr 04, 2008
simplemitch
  • 752 Answers
SOURCE: Error ao pioneer head unit
If the discs PHYSICALLY get stuck, then the mech is damaged. A local shop MAY be able to fix it, but it might be a better investment to just replace the radio.
Posted on Aug 04, 2008
JustJeeps
  • 74 Answers
SOURCE: sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Posted on Nov 21, 2008
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
Pioneer double din issues
Is the video wire grounded out? By law the radio's video wire is supposed to be grounded to your e-brake to insure your not watching a video while driving. The way to get around that is to ground the video wire some where in the car and then it should play on command. If not check your RCA cables if tht dnt wrk then radio I messed up
Jun 30, 2013 | Car Audio & Video
Iam try to wire a aftermarket stereo on a 1987 gmc jimmy using stock plug ins but every time i put on brakes stereo goes off Ive checked all wires to make sure none are bare also made sure nothing...
Could be a ground problem. You take the ground out of the harness and run it to the body or run a ground from the radio back to the body or both.
Sep 11, 2011 | 1987 GMC Jimmy
Radio
Check the connections on all the pins, If it is a plug and play adaptor, check your fuses, but most likely the speaker connections are slightly loose, which is causing the lack of sound. I find when removing stereos if the wires are shorter they disconnect, but stay in the housing.
Oct 21, 2008 | 1998 Mitsubishi Montero
95 ford probe wiring harness. no sound but turns on
Hey I cant help you with your problem but can you help me? i have a 95 ford probe with a metal ended square harness on it, i went to canadian tire 100 times looking for the right harness and none fit it. a couple months later I had found another harness connector a few inches don't from the other square one.Now before i found that one i cut the harness and tried manually connecting them to the new radio. The radio would turn on but now sound would play.... and i tired 9 colour codes still nothing. if you have any idea about my problem it would be much appreciated thanks.
Jun 25, 2008 | Car Audio & Video
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
My pioneer deh-1900 mp will not turn on
Feb 09, 2008 | Pioneer DEH-1900MP CD Player
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
