How to get the top off front loader to change belt
    New Friend:
  • 25 Answers
Some machines you can replace the belt from the back. to get the top off you may have to remove the front of the machine
Posted on Nov 26, 2014
Washer fails to engage agitator or spin cycle but still fills and empty water
Needs a little more info, but if it is a belt-driven machine, the belt could have fallen off, or burnt out.
If a top-loader, tip up and have a look underneath.
If a front-loader, unscrew the couple of screws holding the top on (at the top of the back panel) and slide backward to lift the top off. You should be able to see the belt down the back.
NOTE: Always disconnect from the power prior to doing any work.
Oct 01, 2017 | Washing Machines
My Roper top load washer is making a squealing sound.. Is it a belt?
Most are belt drive on front loaders and on some top loaders but not all. Other culprit can be a dry bearing. Get into it a take a look. A length of plastic hose makes a good stethoscope to pinpoint the noise.
Oct 02, 2016 | Roper Washing Machines
Changing dryer belt
Through the rear if it's a front loader
May 02, 2015 | Dryers
I need to change the belt on front loader amana tandem 7300
The back doesn't come off - the 'shell' (top and sides) come off. Then you should be able to get to belt from the side, you'll need a lot of room to work with it.
Nov 21, 2013 | Amana Washing Machines
How to change belt on whirlpool ultimate care plus washing machine
Top loader? Turn machine up so you can see underneath, remove access panel, belt right in front of you. Fits over motor spindle and base of agitator spider
May 19, 2012 | GE WBSR3140DW Top Load Washer
My machine is not spinning what may be the problem
depends on what brand and type of unit... is this a front loader a top loader and what brand.. is it direct drive or belt driven.... if it is belt driven could be a bad belt or pulley...if it is direct drive such as a top load whirlpool ,kenmore,roper, you could have a bad drive coupling which is located between the motor and transmission under unit.... if this is a front loader there are numerous items it could be example a motor controller board, main pcb board.
if everything is working but the spin mode and this is a top loader unit may want to check the lid swich that will cause the unit to not spin.... hope this helps kinda a vague description of your probelm....good luck and give me a vote i need them....
Jan 03, 2011 | Washing Machines
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Feb 10, 2010 | Washing Machines
How do I change the drive belt on a top loader whirlpool washing machine
WITH THAT MODEL NUMBER, IT'S A FRONT LOADER YOU MEAN. THERE'S A PANEL IN THE BACK TO ACCESS THE BELT
Jan 24, 2010 | Whirlpool GHW9300 Duet Washer
My machine is not spinning when spin is selected
HI. if this is a belt driven top-loader, or front-loader, more than likely, the belt has slipped off the drive pulley, or the belt has failed. Now, if this is a top loader, with a direct drive assembly. the motor coupler will be the culprit in this case.
Oct 13, 2009 | Washing Machines
How to change the belt in my whirlpool washing
It's probably the washer transmission. Belts aren't common anymore & besides it wouldn't work at all if there was a belt broken.
Jun 18, 2009 | Whirlpool Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
