Question about Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8" Shaft 230 V
Cant find a wring diagram for a certain motor I have. Thought this was the 21st century and if you type in the spec number or serial number the wiring diagram should pop up! Guess not. My question is,
Don't know if i answered the part about "what product are you asking about?" correctly. Just picked one.
    New Friend:
  • 42 Answers
Brand name of motor would help. Try the motor brand name web site.
Posted on Nov 26, 2014
When does the 21st century end? 2099 or 2100?
2100 would be the last year of 21st century
Jan 04, 2017 | Homework
I need a wiring diagram
Welcome to the 21st century where wiring diagrams are readily available through an internet search.
May 24, 2015 | Garden
Century motor wire for 115V it a pump for water
What is it that you need to know? What is the code & Serial number of the century motor?
posting a good clear picture of the back end of the wiring area of the motor helps too.
Mar 11, 2015 | Century Pool & Spa
Need a wiring diagram for a century quick fix wire feed welder
If you can give the code code number I can help you. The code number should be in the same plate as the serial and model number.
Jan 19, 2014 | Welding Tools
Replaced an old Magnetek century two speed with a AO smith century two speed. Hooked the wires up the same but unable to get the motor to operate in the high speed mode, suggestions!
Each motor will have wiring diagram on label.
Compare diagram on old motor with new motor.
WIRE COLORS VARY
Which 2-speed timer do you have on the circuit?
Wire lead from NO terminal connects to High speed.
Wire lead from NC terminal connects to Low speed
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Oct 23, 2012 | Pool & Spa
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
What wires do I need to switch to make an AO Smith motor (922L) run the opposite direction?
I can not give you an exact answer as the diagram is not available on AOSmith's website. Generally speaking the wires are a black and a red. It should describe to you the process on the motor nameplate in the bottom right corner. If you are still unable to reverse it, please reply with a comment that includes the motor serial number and I will go to AOSmith's tech support and get the diagram that way.
John
Aug 14, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Century 1HP electric motor Part #8-1286037-20 Type CX Frame L56C Serial BM9-142 I am missing the wiring diagram and want to convert it from 110v to 220v...
Why do want to change it? It won't save you any money, run it on 120 volts unless it's a long distance run and voltage drop is a concern.
Jun 24, 2009 | Garden
Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8" Shaft 230 V Logo
123 people viewed this question
Top Baldor Plumbing Experts
John Loiselle
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Joel Fluth
Joel Fluth
Level 1 Expert
Are you a Baldor Plumbing Expert? Answer questions, earn points and help others
