Vacuums Logo
L
Lisa Nixon Posted on Nov 16, 2014
Does not squirt water out and it does not pick it up, how do I fix it
Jason Largo
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Nov 21, 2014
Jason Largo
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
7280
Points
36
There is a seal or connection that's either loose or needs to be replaced. Contact the manufacturer if you can't solve the problem.
Shampooer wont spray water!
be sure you arefilling the correct resivor
I did that on a friends that I borrowed
Nov 20, 2013 • Vacuums
My bissell proheat will not squirt out water/cleaner. What do I need to do to fix this problem?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
365er6
1helpful
Bissell model 9300 proheat 2x does not squirt water what is the belt number for replacement?
heatman101
djrw
1helpful
Steamvac will not **** up water
Check the lid on the lower tank. The front of the lid lips over the tank to lock it on and snaps in the back. You probably haven't locked the front edge down
Bissell carpet cleaner wont **** water out of carpet.
heatman101
rw245
My bissell worked well cleaning my carpets it's only 1 year old when i stop'd it to refill water it would turn on put not spray what can ido to fix this problem
TAKE OFF THE CLEAN WATER TUB IF IT COMES OFF TO FILL AND LOOK FOR SCREENS OR FILTERS THAT COULD BE PLUGGED OR AT LEAST LOOK FOR THE LINE THAT CARRYS THE WATER TO THE PUMP AND AGAIN CHECK FOR LIKE HARD SOAP AND STICK LIKE A NEEDLE IN IT BUT CARFUL NOT PUNCTURE ANY TUBES THE WORST CASE IS THAT THE PUMP THAT MAKES THE WATER SQUIRT OUT IS BAD SAME AS IT BE IF YOURE CAR STOPPED HAVING WINDOW WASHER FLUID SQUIRT OUT
Jan 19, 2010 • Vacuums
My power steamer will not squirt water. Seems to
it migh be that the formula you mixed together is notcreating enough pressure to force the mixture out is it the formula the company sells or did you pick up some other formula
1helpful
Model 1400 little green cleaner does not squirt fluid
its just the prime.if all the water is let out of the hoses it will need to be reprimed with water again.once water fills the hoses it will work fine
2answers
No water spraying
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Bessell steam cleaner #%$@#%%$%
Model number would help. With water squirt out of the hose? If it does then the heater in the handle is probably clogger and will have to be cleaned out. If no water, then is the pump belt ok? If it is then you could have a bad pump. Also check that the seal is on the bttom of bothe tanks, and not sitting in the hole that the tank sits in. It has to be on the valve on the bottom of the tank.
Feb 13, 2008 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
