SOURCE: i need to extend the drain hose on my hotpoint
Check the inside diameter of the drain hose with a ruler.
Go to your hardware shop and tell them that you want two plastic inline connectors and 4 Jubilee clips for an inside diameter hose of ???
Get a one foot piece of clear plastic tubing from the same place.
Cut the hose in the middle insert one of the connectors and tighten it on with a clip put the plastic tubing on and tighten that
Put a clip on the plastic hose and fit the next connector tighten that up, now fit the original hose end and tighten the clip , job done
Testimonial: "Thank you very much..... a great help"
SOURCE: Dishwasher
you can buy the drainage hose ( B&Q) by the per / m if you can not install a drainage pipe closer.
SOURCE: How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
