If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
This M does no harm. It merely reminds you that you stored something in memory. You can try pressing the AC (Clear All) button. Alternatively, store 0 in all the memories. If I am not mistaken you have 3 memories. Try 0 STO 1 to clear Memory 1 0 STO 2 to clear Memory 2 0 STO 3 to clear Memory 3.
Welcome to Fixya. Heres the meaning that you're looking for.
MC - Memory Clear. this clears all contents of the memory MR - Memory Recall. This displays the current content in the memory MS - Memory Save. This saves the current display to memory. M+ - Memory Add. This adds the current figure to the value already present in memory.
You have memory lock up. to ram clear the machine we need to clear out all memory. ( like it came out if the box )
1. have machine turned on
2. press 8,*,9,#.7 ( this will git you in to the programing of the fax )
3. press start
4. press the # key till memory clear
5. press start !( will clear out all memory )
it should print out a memory clear report
6 press stop key 2 times now lets se how it worked
let me know
good luck
to clear memory(which i must warn will clear everthing) first press function then press the number 9,next press * (asterict) then press the number 8 then press the # key then 7 key, press start, you should see a ram version on screen,then press start again,next press # key untill it say's memory clear,press start and it should say memory clear.
