Question about Snom 300 IP Phone
How to fix snom 300 because it cannot received calls
Snom 300 IP Phone can calls outgoing, But cannot receive calls.It's connection was came from a domain network(LAN).
  • wizbang68
    wizbang68 Oct 14, 2017
    For the phone incoming calls are originating from where? Things to test to determine the scope of the issue. 1) Can another extension call your extension. 2) If you operate a local VOIP PBX (asterisk, 3CX, etc) if no go to 3. 2a) Are you using a service provider outside of your ISP for provisioning of the Trunk Lines. 2b) If the trunk lines are provided by other than your isp AND they are POTS/Analog lines. The issue is most likely with your trunk gateway 3) If you do not operate your own PBX (Phones connected directly to a SIP or you are using a sip provider for the PBX which is not your ISP and the problem is limited to calls received from outside your network. Because we are referring to calls coming from the outside it would often be an issue with a firewall or SBC (Session border controller) which limits access to your sip services without a defined method to authenticate the inbound connection. Often this is done by port knocking (IE: SIP inbound sends transmission to your network requesting a connection to a certain ext on a specific port at a particular timeframe. The response if rejected and the "real" request for connection is sent to the proper extension and port for connection of the call. (but if the first rejected request was not submitted (i.e.: the knock on a specific port for a specific connection to an extension, at a specific time interval) no one will open the door for the real call. Other types of firewall issues could be only accepting sip traffic from the trunk provider ip range. and likewise the trunk provider will only acknowledge traffic from your companies defines ip range. the trunk provider can also choose to block traffic originating from or transitioning through ip addresses of blocked countries. Lastly your phone needs to have the in bound and outbound details and domains set according to the trunk provider specifications, including supported technology and technology which is rejected. Activating a rejected technology may cause their response to not acknowledge your responses to ring the phone to start with. phone logs may give you some help to see what if failing.
    New Friend:
    Problem Solver:
  • 8 Answers
Is your phone connecting to a hosted PBX provider or is it connecting to a premise-based IP PBX? Incoming and outgoing calls are usually handled by two separate connections between your PBX and the service provider SIP trunk. Sounds like a registration problem with the SIP trunk. There is nothing you can do from the phone itself to fix this.
Posted on Jan 02, 2015
SOURCE: can't connect to phone
I bought SNOM 300 and i was unable to connect the router in first go. it was keep saying Send DHCP reqt but nothing was happening. i tried even connecting SNOM 300 dirctly to my laptop but in vain. in last i started receiving message Ethernet cable unplugged.
I reset the SNOM 300 to the factory defaults which solved the problem immediately.
Get to the phone menu "configuration-Reset" and select this option. it will ask for the admin password which is 0000. This will fix the issue. try it.
Posted on Mar 12, 2009
  • 4 Answers
SOURCE: my snom 300 is dialling letters instead of numbers how do I fix
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Posted on Oct 22, 2009
ted1430
  • 339 Answers
SOURCE: Cannot update firmware Snom 300
It's not really asking for a TFTP update, it's just something that is always checked for in the boot sequence.
As for manually setting the networking configuration rather than using DHCP, see page 14 of the manual at
http://www.snom.com/uploads/docu/UM_snom3xx_V2.2_en.pdf
for instructions on how to bypass DHCP and manually configure your settings.
Posted on Jan 09, 2010
  • 6 Answers
SOURCE: snom 300 does not renew ip address on DHCP
reset the vlan settings see if that does the trick
Posted on Jan 14, 2011
SOURCE: my snom 300 phone displays
NR (Not Registered) status is shown on snom 300, when the phone's registration information is wrong. Login to the phone's GUI and double confirm the account details and password. The System Information page details the error. If it's a "Network Failure" error, you probably have to check whether the internet is up and the firewall is allowing VoIP traffic (both SIP and RTP)
Cannit make outgoing calls
below link has documentation , Please go through .It might give you an idea of troubleshooting
http://wiki.snom.com/Snom300/Documentation
Mar 09, 2011 | Snom 300 IP Phone
HOW DO I UNLOCK MY SNOM 300 KEYPAD?
To lock or unlock a Snom 300 keypad you will use the * key. Hold this down until the lock icon appears and hold down again until lock icon is gone to unlock.
Jan 14, 2011 | Snom 300 IP Phone
Snom 300 registered to avaya ses5.2 is having oneway call
check what ports your service needs for voip then open them on your router (under the firewall heading)
Jun 07, 2010 | Snom 300 IP Phone
Hi, our phone here snom 300 cannot read the IP address what should be the best thing to fix this? thanks for the immeadiate reply.
How do you mean it cannot read the IP Address. Default is 196.168.254.2. Type that into a web browser and see if it connects.
Oct 22, 2009 | Snom 300 IP Phone
I forgot the password and cannot access the web interface of snom 300, version of firm ware is 7.3.23, I have tried to reset it but it again asks for password. I have tried user name as 'admin' and...
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Jul 02, 2009 | Snom 300 IP Phone
How to change the IP address manually - through phone interface?
Go here for directions on disabling DHCP:
http://wiki.snom.com/Settings/dhcp
Once DHCP is turned off, you should have the option to manually configure the IP address.
May 25, 2009 | Hawking HWREG1 Repeater
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
Apr 29, 2009 | Philips VOIP8411B/37 IP Phone
Can't connect to phone
Jan 23, 2009 | Snom 300 IP Phone
Snom 300
this is not a solution - we have the same problem too.
have about 70 snoms here and sometimes the display shows only black boxes. a reboot helps then mostly for a while.
telephones are connected by poe or voltage adapter.
never had over voltage and i can't remember on power outages.
Sep 08, 2008 | Snom 300 IP Phone
Snom 300 IP Phone Logo
217 people viewed this question
Top Snom Computers & Internet Experts
David Payne
David Payne
Are you a Snom Computer and Internet Expert? Answer questions, earn points and help others
