Question about Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz, HDTV
Coby 40" shuts off?
The tv will work for hours, and than either shut off the video, or the audio and keep the video, or go to stand-by/blue screen. Upon shutting the TV off, and than turning it back on, it works for hours before the problem returns?
    Top Expert:
  • Coby Master
  • 74,383 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 16, 2014
Testimonial: "This gibberish is redundant. Replacing the PCB is common sense....and, has already been done. There is absolutely no need for a TV repairman anymore. Parts are modular, require a screwdriver to replace, and are cheap on eBay...in this case, the PCB was $20, shipped. Please spare us all that rhetoric,and simply offer simple suggestions like, replace this, or this. Also, the links provided went nowhere....and your English is terrible."
  • The Knight
    The Knight Nov 17, 2014
    My English might be terrible, because, my mother tongue is entirely different to that of English. You can't even speak a word with my language. Mind it always. You've the screw driver. You know to screw a PWB to your cheap Chinese set. Do it again and again. Wish you all success. I'm totally ignorant in this field. I do admit it. Good bye.
  • 12 Answers
SOURCE: my coby tv has a
This is usually due to the tv's power supply shutting it down to prevent further damage. It does this when one of the other boards in the set is drawing more power than it should, indicating a faulty part on the board. This needs an experienced engineer to diagnose and repair it, and as this is a common fault with flat screens of all types, should not be too expensive, depending on the price and availability of spare parts.
Posted on Jan 13, 2011
  • 8457 Answers
SOURCE: My Coby tv's VIDEO turns off after a few minutes
Ur backlight IC inverter board is dead.Tries disconnectors & reconnectors the connections to the board see if it work?
Posted on Sep 03, 2009
  • 95 Answers
SOURCE: Lost TV remote for Coby Flat Panel TV, 17inch
Universal remotes are not compatible with any Coby TV. You can get a remote directly from Coby:
Send:
$6 Money Order - 'Made out to Coby Electronics'
note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
Posted on Aug 23, 2008
SOURCE: My Coby 40 inch HDTV wont turn on. The blue light
I had a 32" Coby that did the same thing, turned out to be a defective main board. The main board wasn't sending the 3.3v signal to wake up the power supply. In my case I sold the tv for parts because it wasn't cost effective to replace the main board. It sound like your main board
Posted on Apr 11, 2012
SD Tech
  • 14553 Answers
SOURCE: My coby tftv3229 wont turn on and I've only had it
If its two weeks old why are you here? Take it back to point of purchase and either have it fixed or replaced or get a refund.....
From the brand you likely are in UK but here all sets come with some kind of warranty==the problem sounds like a power supply issue but if you have a warranty and open the set it will void that warranty.
Can a tv inverter board cause tv to not display
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Apr 17, 2015 | Coby 40 TFTV4028 LCD TV
While watching satellite tv, receiver will work fine for a good while (an hour or more), then you begin hearing what sounds like static in the right front channel, followed shortly after by the receiver...
Sometimes equipment gets too hot and starts glitching. Try an improve cooling and air circulation. Often standing the thing on one end so it's tall will help keep it cool. See if it goes for longer with better cooling.
Oct 29, 2013 | Denon AVR-1911 Receiver
Proscan 40lc45s won't stay on
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Proscan 40LC45S 40 in. LCD TV
My Coby 40 inch HDTV wont turn on. The blue light on front (standby?) is on but I can't turn it on. Help I don't wanna buy a new tv
Apr 10, 2012 | Coby Televison & Video
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz, HDTV Logo
152 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
