Question about Cameras
Brand new wildgame innovations model m6b does not work
Just got it today, put batteries in it, it powers on, but nothing happens after. tried turning it off holding the on/off button, nothing, still was on. waited 5 minutes, tried turning it off, didn't want to turn off. all the characters on every line was frozen. tried the reset button, nothing. removed the batteries to turn it off, put it back in, turned it on again, and same thing happened.
    Master:
  • Cameras Master
  • 442 Answers
Sounds like it's broken. If it's new, I'd return it if you can. Even if it's something you can get past on your own it may indicate other problems and you don't want to risk it going out when you need it.
Posted on Jan 05, 2015
SOURCE: Won't stay turned on
Since mine was only a day or two old, I took it back to the store and got it replaced. Since then, it's been fine. Hope you have the same option.
Posted on Sep 01, 2007
SOURCE: Camera wobn't turn on & lens stuck in out position
Apparently the problem with my camera shutting down and the lens staying out, was the rechargeable batteries I was using. They basically lkicked the bucket, and were no longer working., I bought a new set of lithium batteries and the camera is working fine now.
Posted on Jun 20, 2008
  • 23 Answers
SOURCE: Camera Keeps freezing/turning off
Sounds like the camera is writing to the CF card. If this is after taking several shots, even worse in continuous mode. That's why it won't shut off or anything, it has to finish that before it will shut down. If you have access to one try a different card. Remember to reformat it in this camera. Page 38 of your manual. If that works for you take the card into a camera shop and ask them if they will do a low format a newer camera like a XSi, then reformat it in your camera again before you use it.
Posted on Dec 06, 2008
  • 11967 Answers
SOURCE: my camera is frozen and won't turn on or off. it
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 15, 2009
SOURCE: Kodak Z1012 WON'T TURN ON!
My Kodak camera will not come on..... it is hardly used and NEVER abused..... I fixed mine by calling Kodak Tech support and listening to their **** about i can send it in and get a refurb model for $ 110.95..... My fix, I went and bought a FUJIFILM S2550. Kodak level of quality sucks....
Posted on Dec 02, 2010
Where can I find a manual for wildgame innovations model 15D
Try Googling (wildgame innovations)(15D)(manual) without parens.
Oct 12, 2017 | Wildgame Innovations Cameras
Wildgame innovations manual for model K7i5T5
Try Googling (wildgame innovations)(K7i5T5)(manual) without parens.
May 24, 2017 | Wildgame Innovations Cameras
User manual for wildgame innovations model #T10i35T4
Try Googling (Wildgame Innovations)(T10i35T4)(manual without parens.
May 23, 2017 | Wildgame Innovations Cameras
Need a manual for Wildgame Innovation Camera ir4
The Wildgame Innovations website is glitchy at present, but seems to indicate the manual is available from them for download when I put 'IR4 Manual' in the upper right search box. Site is currently reporting Gateway Time-out.
http://www.wildgameinnovations.com/catalogsearch/result/?q=ir4+manual
Nov 03, 2015 | Wildgame Innovations IR4 Digital Camera
Can not get camera to stay on? Powers on then shuts off
Usually that happens when the batteries are low. Try checking the batteries.
Jan 12, 2015 | Wildgame Innovations 2Mp Red 2 Enhanced...
Cannot get my wildgame innovations camera to turn on.
What model is this? Does it have a reset button? If it does, when you press it does the LCD come on then drop out?
Oct 27, 2013 | Wildgame Innovations 6 MP Micro Digital...
My wildgame camera model S4 will not power back up, I've changed the batteries twice and checked them with a volt meter to make sure they are good. I've only had the camera for 1yr.
1) memory card slot/batter covert is open
2)batteries are loades in the wrong direction
3) insufficiente battery voltage
4) poor contact between camera and battery terminal
5) swtich is fault, measure continuity.
God bless you
Oct 17, 2012 | Wildgame Innovations S4 Digital Camera
Cameras Logo
138 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
