Question about Garden
Still chainsaw ms260z will not start
Got spark and fuel
  • 1,169 Answers
If fuel is making its way to the cylinder and the plug is wet then check the following
1) For clogged spark arrestor if fitted with one.
2) Compression - Needs to be at least 100 psi to ignite the fuel mix
3) Flywheel shear key - A sheared key will have the ignition timing too far off to start.
Posted on Nov 16, 2014
5 Suggested Answers
SOURCE: 350 chainsaw will not start and run, getting fuel
check set screws on the side of carb turn the all the way in the turn out till idles or check the screen in the muffler
Posted on Feb 04, 2010
  • 136 Answers
SOURCE: my husqvarna chainsaw wont start
Try bypassing the switch by connecting the two wires together. If it starts then you know what the problem is.
Posted on Nov 25, 2011
  • 320 Answers
SOURCE: factory carb settings for dolmar ps460 chainsaw
Try squirting a little starting fluid into the carb and try to start. If it will try to run, you have a fuel problem. Try changing the fuel filter first.
Posted on Apr 07, 2012
SOURCE: Chainsaw won't start. Has spark, has fuel, chain
It starts but won't stop when switched off by stop button it's a husky55
Posted on Jul 21, 2013
Try putting another new spark plug in it. If that does not work then turn air fuel mixture screw on the carb. all the way to the right then about one half turn counter clockwise and make sure the on/off switch is in the on position. If the saw has been sitting for awhile the carb. may have to be cleaned out. If still no response then take the saw inside and try to warm it to room temp. If still not starting spray a little bit of starter fluid in the intake or wd40. Then see if it will fire up.
Nov 15, 2014 | Garden
Trouble shoot polan pro chainsaw
Use a cheap spark checker to check for spark. To check for fuel issue, squirt some carb cleaner down carb and see if it hits. If it does, you know you have spark and the problem is in the fuel supply.
Jun 16, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Toro snowblower troubleshooting
FOLLOW this steps and fix it. Merry Christmas
Spark Plug
Every chainsaw relies on a spark plug to ignite the air-fuel mixture for proper combustion. Over time the electrode on the spark plug will burn away and the engine does not start. If the engine does not start, remove and inspect the spark plug. If there is any doubt that the plug is working properly replace it.
Enter your model number to see parts for your chainsaw.
Carburetor
If the chainsaw won't start, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the chainsaw for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn making it hard to start the engine. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
On - Off Switch
Chainsaws are equipped with an on/off switch. If the chainsaw does not start, this switch might be defective. Check the switch for continuity. In the on position the switch should have continuity.
Safety Switch
If the chainsaw does no start, the safety switch - or throttle control switch - might be defective. If the switch isn't engaging with the throttle it won't provide enough fuel to the engine and the engine does not start.
Ignition Coil
If the chainsaw engine does not start the spark plug may not be getting voltage. Power to the spark plug is provided by the ignition coil. The ignition coil is mounted next to the flywheel. As the flywheel spins an electrical current is induced by the ignition coil. If the ignition coil is defective it will need to be replaced, it is not serviceable.
Rewind Spring
The recoil starter assembly has a rewind spring which spins the pulley backward to rewind the starter rope. If the rewind assembly is broken the rope will not rewind and the engine does not start.
Recoil Starter
If pulling the recoil starter assembly handle doesn't engage with the engine and the engine does not start. Repair or replace the recoil starter assembly.
Recoil Starter Pulley
The recoil starter pulley winds up the starter rope when not in use. If the recoil starter pulley is broken or stuck it may not rewind the rope and the engine does not start.
Dec 19, 2013 | Toro Garden
I HAVE A POULAN 2150 CHAINSAW WITH A WALBRO WT 324 CARBURETOR. IT WILL CRANK WITH CHOKE ON BUT CUTS OFF SOON AS I PUSH CHOKE TO OFF POSITION
test the steps and fix it. God bless you
Spark Arrester
Inside the muffler of most chainsaws is a screen-like device called a spark arrestor. If the chainsaw stops after a few seconds or won't start at all, the spark arrestor might be clogged. The spark arrestor prevents small embers from being emitted by the engine to prevent fires. Over time the spark arrestor will become clogged with soot. Remove the spark arrestor and clean with a wire brush or replace.
Carburetor
If the chainsaw engine stops after a few seconds, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the chainsaw for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Gas Cap
The gas cap on YOUR chainsaw is designed to let a very small amount of air into the tank. This is necessary because as fuel is consumed a vacuum is created in the fuel tank. The gas cap has a tiny vent to let air into the tank and equalize the pressure. If the gas cap vent gets clogged air can't enter the tank and eventually the vacuum pressure in the tank exceeds the vacuum pressure of the engine, and the engine stalls. The vent often cannot be cleaned because it is made of a semi porous ceramic material. If the gas cap vent is clogged, replace the cap.
Spark Plug
If the chainsaw starts and stops after a few seconds The spark plug may be defective. Although this is not very common it is easy to test. Try removing the spark plug and installing a new one.
Fuel Filter
If the chainsaw stops after a few seconds, the fuel filter might be clogged. If old fuel was left in the chainsaw for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the fuel filter and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old fuel from the fuel tank and replace the fuel filter.6ad91f3f-147a-4ac3-97cd-7e13c345e87d.jpg
Nov 23, 2013 | Garden
Apr 04, 2012 | Homelite Garden
My chainsaw will not start
You need to do some basic tests, start by draining the fuel tank and refill with fresh fuel oil, pull the fuel hose out of the tank and fit a new fuel filter, remove the spark plug and check to see if you have a spark, if you have a spark and the plug is soaked in fuel, leave the plug out and let the machine dry out for a few hours and try re starting with no choke.
Mar 06, 2011 | Poulan Garden
Try getting a new fuel filter. I sounds like its not getting fuel.
Also make sure that you are getting spark.
May 03, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
