Question about Stihl Garden
Ms 260z will not start
I've got spark a fuel just won't fire
    Genius:
  • Stihl Master
  • 2,485 Answers
Fit a new plug but first pull it over with the plug out to see if there is to much fuel in the bore, turn it so the plug hole is pointing to the ground leave it turned off to avoid a fire, try either if not enough fuel
Posted on Nov 16, 2014
2 Suggested Answers
2strokeJim
  • 577 Answers
SOURCE: Stihl MS 290 won't fire even when primed directly into cylinder
crank seals are probably shot :-(
Posted on Nov 29, 2012
Acura Legend 86 wont start after initially running fine
fuel pump going out and it will not run at all
coil problem will starteasy but fail after running for a while
fuel pump relay again it is running after starting and if the relay is no good , it will not pump fuel
try having the fault codes read first then have the faulty sensor replaced
May 13, 2017 | 1986 Acura Legend
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
2001 Nissan Pathfinder won't start, fuel pressure ok, spark plugs not firing
make sure you have fire at the coil if not there will be no fire to the plugs
Feb 08, 2013 | 2001 Nissan Pathfinder
1995 Ducati 750 ss wont start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
1999 750SS engine turns over but won start Ducati ms The Ultimate Ducati...
Ducati won start Biker ie Forums
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Jan 10, 2013 | 2002 Ducati 750 SS
What's your problem?I've got a k650 partner saw that was starting and running great, really great. It ran out of fuel, we filled it, it ran for another 5 min and then died out. It didn&
You need to check it is mechanicaly sound, a compression test will give you a good idea, anything under 110 psi and you have a problem with either piston/ring wear, or it has seized.
Aug 05, 2012 | Garden
My s10 truck is gettin fire, gas and air.. will turn over but will not crank.. what could be the problem?
Just because it get fuel,but does the fuel injector pulse? Add fuel in the throttle body if it wants to start your problem and solution will resie in bringing the fuel injector to working level
Apr 13, 2012 | Chevrolet S10 Cars & Trucks
My 1990 3.0 Toyota 4 runner won't start in the cold
If you have spark and fuel, the next stop would be either the crank position or camshaft position sensors.Either one of those can stop the engine from firing.
Mar 16, 2012 | 1990 Toyota 4Runner
Garden Logo
48 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
