Question about Garden
<!-- from fixya rte -->How to level lawn mower deck - Garden
  • 95 Answers
Check air pressure on all tires first then park on flat surface and adjust until the blades are the same distance from the flat surface on both side & front & rear.
Posted on Nov 24, 2014
  • 6 Answers
SOURCE: need diagram for deck belt
Try http://www.rcpwparts.com/parts.asp
Posted on Apr 22, 2009
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 376 Answers
SOURCE: were do the spings go on a yard man riding lawn
Or, you can go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Then enter the brand (Yardman) and model number (from under the seat), hit search. Then look under 'illustrated parts' to mower deck.
Posted on Jun 25, 2009
SOURCE: diagram for belt on mower deck of an old Roper
I think I have a diagram for this, what hp is the mower 12hp? what size cutting deck? I have an old roper 12hp which needs a new belt but don't know what size belt to buy?
My email is richy.furlong@hotmail.co.uk
Posted on Oct 06, 2009
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
How do I level deck
Park your mower on a level surface and loosen the bolts that hold the mower deck up on both sides. There are some good YouTube videos that show you how. https://www.youtube.com/watch?v=cQQXtcMzbGA
Feb 11, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck is not level and mower blades are not the same height
Usually you can solve this problem by leveling the deck. Many mowers have adjustment nuts on the ends of the brackets that attach the mower deck to the frame of the mower. First park your mower on a flat surface like a sidewalk or driveway. Then place a small level on a flat area of the mower deck, then turn the adjustment nuts until the deck is level.
Jul 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
My Craftsman 42" lawn tractor
I would suggest checking your owner's manual. There is a leveling process and my Craftsman wasn't leveled at the factory. Once I leveled mine, it cut fine. If you can't find it in your manual, google leveling craftsman mower deck.
May 14, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
How do u level a exmark 60 inch cut lawn mower deck
Hi cmarze, I'm an Exmark representative. Thank you for your inquiry. In an effort to better answer your question, can you please provide us with your model number?
Jan 25, 2011 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Replaced blades duel deck high spot in cut grass on right hand side. thanks.Mower is rover lawn king.
Try leveling your deck beacuse it sounds like the right hand side of the deck is too high causing the high spots. move the mower to a flat surface, drop the deck to its lowest point and measure the deck height with a tape measure.
Nov 27, 2010 | Garden
I have a problem leveling my mower deck. I level it at the sides and front .I use the mower and it cuts uneven. mower is deck is out of alignment. less than 1 hour on it.
The deck could be bent, or you will probably have to level the back of the deck as well. Another thing to check is the air in the tires, this can cause an uneven cut. Although the tire may look pumped up, with the weight of a person on the tractor can cause an uneven cut.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 20 HP Sears riding mower with 42" deck. Something has caused the right side of the deck to sit lower. It literally sits on the ground when lower to #1 position.
There are deck leveling adjustment bars located on most lawn tractors, most are equipped with a large plastic wing nut. There will be one on each side, with the mower off, lower the deck to the lowest position, loosen the wing nuts on each side, then re-tightnen. There is also a possibility if this is not the way your deck is levelled, there will be a deck hang wire/rod, however those are usually found on zero turn style mowers.
Apr 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I adjust the deck level on a Husqvarna riding mower?
Not sure if you are looking for the nuts and knobs or how to level? Most newer decks have knobs for adjuctments. I park my mower on a concrete level surface make sure all tires are at the correct psi then with tape measure check front left and right at bottom of deck for same measurment. You can also put a 2 ft level on the deck and adjust.
Mar 13, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower Deck not level
there is a geared bolt at the deck suspension un lock it and rotate it will raise and lower the deck
Jul 31, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
