Question about Boating
Where can I bring my Heart interface freedom marine 10 1000 watt 50 amp inverter charger to get repaired... I live in merritt island florida
  • Boating Master
  • 696 Answers
Hi Nick!
I would strongly suggest contacting Xantrex service. IF your unit is still under warranty, it could save you some cash. If not, here's their contact info:
http://www.xantrex.com/power-products-support/overview.aspx
Posted on Nov 16, 2014
SOURCE: Heart Interface link 1000 Manual??
Check the manufacturer web site:
Product Page:
http://www.xantrex.com/web/id/98/p/docs/pt/7/product.asp
User Guide:
http://www.xantrex.com/web/id/423/docserve.aspx
Posted on Apr 30, 2009
SOURCE: I have a Heart Interface Freedom 20
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Posted on Jul 04, 2009
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Posted on Sep 08, 2009
nitrospawn
  • 290 Answers
SOURCE: Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Posted on Feb 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: my 2000 Fleetwood Discovery Motorhome
Terry this unit has 2 AC outputs so the reading that you got is correct. I am trying to surmise the actual problem that you have. You may have lost a system ground in the mobile home which would give you power as you stated but no power to the mobile home as the system ground has been lost.
Dumb questions time.
1. Battery voltage above 10 Volts?
2. Have you checked the DC Fuse?
3. Have you reset the breaker on the control panel?
Last test.. is to disconnect all outputs and try a voltage test again. A system distribution short will cause the inverter to go into the self protect mode.
Kelly
Posted on Aug 25, 2010
Hi Nick!
Nov 15, 2014 | Boating
My heart interface freedom model 20 - blew up- what would be a good replacement or do i really need a inverter in my motorhome
The other thing to consider is that auxiliary batteries need charge while sitting, plugged in, which can be accomplished other ways.
Aug 05, 2011 | Xantrex Technology Heart Freedom 20 12...
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
HEART 25 INVERTER
if the charger will not charge the batteries, it means the charger is bad or the fuse for the charger is broken
Mar 18, 2009 | Xantrex Technology Heart Freedom 25...
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Boating Logo
80 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
