Question about Building Materials
Garage door opener remotes work OK on OPEN but have short range on CLOSE.
In the last week or so, the garage door remotes work normally of OPEN but only at short range on CLOSE. Replaced batteries on both remotes. No change in this behavior. If it's RF interference, then it would have to be at the CLOSE frequency and not the OPEN frequency .. if there's any difference. Can't imagine what source of interference anyway. So....?
  • fmarshall Nov 30, 2014
    I found the problem: Modern light bulbs such as fluorescent AND LED can generate radio interference. I had installed an LED bulb in the door opener. That was the problem.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
Try adding on the antennaes, ive had success with this in the past
Posted on Nov 30, 2014
Testimonial: "I found the problem: Modern light bulbs such as fluorescent AND LED can generate radio interference. I had installed an LED bulb in the door opener. That was the problem."
ltfrc
  • 227 Answers
SOURCE: remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Posted on Feb 06, 2009
  • 10 Answers
SOURCE: Garage Door Remote
find attena and point it to your door if this does not work try adding a piece of wire to attena and making it longer also always check batts...
Posted on Apr 05, 2009
  • 3197 Answers
SOURCE: garage door remote control signal problem
On the rear of the motor unit just to the left of all those white wires you will find a small LED. Random flashing is normal but if it is flashing rapidly it shows some type of interference. If this isn't happening then the most common thing is a logic board going bad.
Posted on Sep 01, 2009
  • 3197 Answers
SOURCE: Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Posted on Sep 12, 2009
  • 158 Answers
SOURCE: We are having intermittent problems with our 2
Greetings LiftMaster Owners:
You are probably getting signal interferences from other devices in the neighborhood or from your home that are on the same frequencies as your remotes and garage door openers. Weather conditions can lock signals and frequencies into a much smaller area concentration causing these interferences. Check you home owner manuals for the grarage door opener and see if there is an adustmen on the garage opener that can strengthen your signals. Good Luck
Posted on Oct 14, 2009
The key pad will close the garage door but it will not open the garage door.
If the keypad is the only remote unit you have that has short range then it is failing. The lack of signal strength prevents the signal from reaching the receiver when the door is closed. A replacement is the only cure.
Nov 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
I really need your help. My Craftsman unit model number is 139.53615SR manufactured 1/92. I have a three car garage. The original two remote controls were lost and since then I've used the setting in my...
Have your neighbor bring over his remote and open or close your door with it. Then hold the smart/learn button in for 6 seconds on your opener. Then see if he can open your door. He shouldn't be able to because that procedure erases the memory in your opener. No remotes should work. You need to get that remote #53778 back and program it and then see if your neighbor can open your door. If he can open your door at any point after you have held that button in for 6 seconds you need to get a new door opener.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
When I enter my code on the keypad it will not open the door, however, if the door is open and I enter my code it will close it. also one of our remote openers has stopped working, batteries have been...
If your remaining remote(s) have normal range then it is your keypad that is going bad. When one of the units start loosing range it is common for the door to cut down even further on the signal strength.
Feb 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have problem, with my door garage. it desn't
IF THE DOOR OPENS WITH YOUR REMOTE BUT DOESN'T CLOSE (AND WORKS NORMALLY FROM THE WALL BUTTON) THE PROBLEM IS IN THE SAFETY EYES - CHECK TO SEE THAT BOTH LED'S ARE LIT.
IF NOT CHECK WIRING POLARITY - CHECK FOR BROKEN WIRES - CHECK FOR ALIGNMENT AGAIN.
Sep 06, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage Door Remote
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door works when it wants to.
You have a problem with the safety eyes. Make sure a light is on on both eyes. If not, realign until both lights come on.
Jan 21, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears garage door remotes
Tilt antenna different direction. Call Liftmaster for advice
Oct 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
64 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
