Question about Saws
The blade tilt mechanism is very hard to move. Hard to turn wheel to adjust the cutting angle between 90*and 45*. how do I fix this?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Usually this is due to debris in the trunion or gear set. Take some time to clean it all out, then use a small amt of oil to lube ways and gears.
Posted on Dec 08, 2014
efs_perpends
  • 1996 Answers
SOURCE: Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
efs_perpends
  • 1996 Answers
SOURCE: dw703 beval adjustment
User manual for adjusting your saw here.
When you set it up, make sure you check for square to the table, square to the fence, and check square for toe-in or at a 45 deg. angle across the blade from the corner where fence meets table, like you would check a radial arm saw. (hold a framing square with one leg against line of fence/table and other leg against blade and inclined 45 to both table and fence. Make sure all three are dead square.
I never found any way to compensate for the play in the blade itself. It seems like the manufacturing tolerances are a little too loose.
You may need a heavier plated blade. You may simply need a different saw. Those Dewalts are great workhorses, and I love the design, but it's my experience that when you're trying to miter hardwoods of any substantial size there's a little bit of drift in the cut as the blade comes through the wood.
You can try cutting at a slower rate.
I've found that makitas are a little more solid through the cut, though I don't like the general ergonomics as much...
Kind of a pain, isn't it?
Well, good luck.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 07, 2009
SOURCE: can't tilt blade more than 15 degrees
Follow the blade calibration procedure in the manual.
Unplug.
Take off the back and look at the worm assembly. I think you will find the stop toward the right loose allowing this problem.
If you adjust it (you'll need a 3mm allen wrench) per the manual, it should be fine. I just finished aligning my saw at 90 and 45 degrees and though it is a bit tedious, it isn't difficult.
Good luck.
Tony Vlasak
Posted on Oct 06, 2009
  • 5 Answers
SOURCE: craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Posted on Dec 21, 2009
agent91
  • 2100 Answers
SOURCE: Cutting 45's on my Dewalt 744
I don't know why it's rubbing, did you try the small one to see if it is different in some way? How about the stop screw, is it 45 degrees or more? Check it with your speed square. And yes, make a custom plate out of plywood. Which way does the blade tilt? Left is best, locking your work against the fence is the worst idea I have ever seen, (delta) It sounds like the big plate is for a dado blade.
Posted on Feb 28, 2010
The blade on my new skil 3310 won't raise. It came preassembled & has never been used, but the elevation wheel feels locked. I can adjust the angle, but turning the knob doesn't raise/lower blade.
Just as a question and I am not being smart you know that the wheel to raise the blade work counter clockwise.
The other thing you need to check is in your manual here is the part how to adjust the blade for raisin/lowering.
After five hours of operation, the blade elevation/tilting mechanism should be checked for looseness, binding, or other abnormalities. Disconnect the saw from the power source, turn the saw upside down and pull up and down on the motor unit. Observe any movement in the motor mounting mechanism. Looseness or play in the blade raising screw 1 should be adjusted as follows (Fig. 55): 1. Loosen nut 2. 2. Adjust the nut 3 until it is finger-tight against the bracket 4, then back off the nut 3 1/6 turn. 3. Tighten nut 2. The maximum allowable play of the screw rod 1 is 5/32" (4 m). Place a small amount of dry lubricant (such as graphite or silicon) on the screw rod 1 at the thrust washer 5. Do not oil the threads of screw rod 1. The screw rod 1 must be kept clean and free of sawdust, gum, pitch, and other contaminant's for smooth operation. NOTE: If excessive looseness is observed in any other part of the blade elevation mechanism or tilting mechanism, take the complete unit to an authorized service center.
Oct 21, 2015 | Skil Saws
The blade tilt apparatus on my Delta 10" 36-430 is very hard to operate. How do I fix this?
Lubricate it with a silicone grease and that will fix it right up ! 25285410-1e14llyhpwl0cobp50jzv4ab-3-0.jpg
Nov 15, 2014 | Saws
How to square up my saw and where I get a copy of the manual
With the saw unplugged manually pull the blade guard fully open and use a strong elastic band/string or otherwise wedge it open to give yourself full access to the blade.
Use an engineers square or at a push a good carpenters combination square measure the angel between the blade and the saw bed. you might find it's slightly off 90 degrees.
Ok, depending on the make of saw there will be a screw thread at the front or rear of the blade on on or close to the pivot points (where the bed tilts to allow different angles to be cut). it usually has a loking nut. Slacken off the locking nut and also slightly slacken off the tilt adjusting screws. You should be able to easily move the bed in relation to the blade. You will see the bed hitting the bottom of the adjusting screw.
Gently turn the screw and keep measureing the angle with the square. Make sure that the squares blade is tight to the saw blade and not touching the small tooth at the edge of the blade. there should be absolutely no gap either on the saw blade or saw bed when its correct.
Holding the screw with one tool getly tightedn up the locking nut ensuring that the main screw does not move.
CHeck everything again and tighten up the tilt mechanism.
Let me know with pictures if you need more exact info for your saw model and I can point out the parts.
Sep 13, 2014 | Saws
My Grinder is jammed wheel is moving very hard what should i do please suggest immediately
Just a shot in the dark, check to make sure "lock" is not partially engaged (Black button on top of grinder used when changing blades/discs)
Feb 28, 2011 | Bosch 5" Paddle Switch Small Angle Grinder
28-276 Delta bandsaw blade keeps coming off?
Unplug the machine, gain access to the two wheels. On the back of the machine you should have a tilt adjustment knob. Manually turn the wheels in the direction of the cut and at the same turn adjust the tilt knob on the back of the machine. This should solve the problem.
Sep 27, 2010 | Delta 28 168 Bench Band Saw Blade 56 1/8...
How do you cut angles on this saw. It was given to me and I can figure out everything else but cutting angles. Thanks
When you are facing the front of the table saw. Right above the Dewalt logo, there is a hand wheel that if you crank clockwise - it will tilt your table saw blade to the angle shown where the hand wheel is.
May 12, 2010 | Dewalt DW746X 10" woodworker's table saw...
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Blade does not cut straigt. How do I adjust the
There shoul be a scale and a crank or screw used to adjust the blade angle on the front of the saw blade feed bushing. Make sure you set this to 90
Feb 26, 2010 | Dewalt & Variable Scroll Saw
1/8" metal blade keeps coming off
Yes there is a tilt adjustment on the top wheel used to set the tracking of the blade, a small amount of adjustment will change tracking dramatically
Mar 23, 2009 | Saws
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Saws Logo
49 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
