Question about Garden
I have a mastercraft arc welder that turns on but won't arc the overload light is not on or enything
  • 5 Answers
I'm not familiar with this model and I don't know it's age, but as a general check item on any welder, make sure your welding leads are in good shape and that your earth clamp is actually connecting to it's lead. They can burn and tarnish with use and fail to connect. Check likewise the lead connection into the electrode holder. Check their attachment to the welder unit too. There may be a thermal overload protection fuse/device/switch inside the unit which may need to be reset/replaced if you've worked it heavily recently.
If the welder is TOTALLY silent when you switch it on, it may indicate a transformer failure for some reason, usually there is a little bit of buzz or hum. Within safe limits (bear in mind there are dangerous high voltages inside the welder) you might use a simple multi-meter to check that you are getting transmission of power from A to B throughout the unit to the work piece, and that you've got adequate voltage arriving at the work. More safely, with input power totally switched off and unplugged, you can use a multi-meter to check continuity of circuits through the welder to make sure there isn't a break in connection somewhere from a component fault or failure.
Posted on Dec 02, 2014
  • Bob Jones Dec 02, 2014
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 97 Answers
Has the unit ever overheated or gone past the duty cycle while welding causing it to shut down?
Posted on Nov 27, 2014
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: MG 255 MIG welder purchased
Hi and welcome to FixYa, I am Kelly
This is from memory and not out of any manuals so if the solution does not fit your unit feel free to see other Experts advice.
My experience as a welder if you have wire feed and gas is that there is a problem with the ARC voltage. Most units have a potentiometer (pot / dial) to control the ARC voltage. If the pot wiper is dirty you may not be getting the proper ARC voltage. Move the ARC voltage dial rapidly full range several times, (20 or more). This usually cleans off the pot wiper arm and the unit will operate normally again.
Is this a Cornwell unit? There are many different MIG 255 units out there and I did not equate the MG255 to a particular brand. I did see Cornwall nmentioned 2 times.
Even if this does not work for you I would appreciate any future feedback even if your seeking other advice.
Kelly
Posted on Jul 24, 2011
My Millermatic 230v wire feed welder shut off during use and will not turn back on ?
if you use the welder for too long at high amps it will go into over heat mode and shut down
you may have to reset the overload control ( how to do is in the user manual)
mig welders need a cooling of period during use and it is stated in the duty cycle specifics for the machine
contact the service shop for exact details
Apr 27, 2015 | Welding Tools
My mastercraft ark welder turns on but won't ark the overload switch is not on
Get someone with electrical knowledge to test the circuits. Do you mean an Arc Welder or do you mean a MIG Welder? They are completely different in operation.
Nov 15, 2014 | Garden
Spool won't turn
are the rollers tightened enough, also maybe the wire is jammed in gun.
Feb 02, 2013 | Hobart Handler 125 115 Volt 30 To 125 Amp...
I have a champion 10000 watt gen welder won't bur
Make sure the switch for remote power or control at machine is on the right setting. It will arc but very faint if this switch is not on the right setting.
Mar 17, 2012 | Hobart Welding Tools
When the welder is first turned on I can weld with gas for about 5 seconds. Then the breaker trips. ( i have the proper wiring and breaker). The more times I reset the breaker the shorter the weld time...
Hi:
Just make sure that if you are using an extension cable between your machine and the power outlet, this cable is at least a 12 gauge size, if you are using a 14 or 16 it's too small to handle the amps.
Other point is to check that your breaker is 20 or 30 Amp capacity.
Hope this help.
Sep 08, 2011 | Clarke Power Products Clarke 130EN...
I bought a 20 amp arc welding kit from canadian tire and dont have an instruction manual with it. i have given it the proper electrical current and amperage and still cant get it too work. looking for the...
20 amps seems like a fairly feeble arc welder--most light models run up toward 80 to 100 amps for a stick welder with wire feed models somewhat lower. Even accidently touching the two leads together should have produced some arcing. You may have a defective unit. Hope this helps!
Aug 16, 2010 | Garden
Ave a power mate 225 amp 240 volt welder that wont arc
Sounds to me like the Power Controller has gone bad. These are a real tricky, dangerous, things to fix yourself, I recommend that you call the service rep, for Power Mate,and cut your losses.
Feb 24, 2010 | Welding Tools
I have a speedline 180 amp arc welder and it doesn't want to arc i turn welder on it makes the nose its spose to make and i connect my earth go to strike and nothing happens? any ideas??
Check for output voltage (ac or DC depending on model).No voltage,welder has a problem.
You must have a clean ground clamp attached to bare metal with some welders to make them work.
Sep 08, 2009 | ARC Welding Tools
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
