Question about Saws
The blade tilt apparatus on my Delta 10" 36-430 is very hard to operate. How do I fix this?
When I have to change the angle of cut from 0 to 45 the adjusting wheel is very hard to turn. what do I need to do"
  • 84 Answers
Lubricate it with a silicone grease and that will fix it right up ! the blade tilt apparatus on my Delta 10
Posted on Jan 08, 2015
  • 187 Answers
SOURCE: I have a Delta heavy
I have the same saw and love it. There are mounting bolt under the table between the blade and the motor. There not ment to be used for adjusting but there is some play. The way to get the best cut is to adjust the fence to the blade. I have a Bessimer fence that adjusts easily with two allan machine screws the push plastic pads against the arms rail. I get cuts that look like DA with 220 was used. Enjoy the saw and good luck.
Posted on May 08, 2009
efs_perpends
  • 1996 Answers
SOURCE: Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 251 Answers
SOURCE: I have a Delta TS300 table saw, need to adjust
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/EnA06547.pdf
Posted on Oct 25, 2009
  • 5 Answers
SOURCE: craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Posted on Dec 21, 2009
al_kupchella
  • 843 Answers
SOURCE: I inherited an older Delta 10 inch table saw.
Two easy possibilities are that the blade is dull or that the wire is too small. The wire is likely to be a problem if you are using an extension cord. You could move the saw near to an outlet that you know to be wired with 12 gage wire (not 14). Or you could buy as short as possible 12 gage extension cord. If being underwired is the problem, you will notice that the motor comes up to speed much faster when wired adequately. You might also buy a cheap new blade to rule out the dull blade problem. If neither of these fixes the problem, then the motor has become "weak" because it has overheated just enough to cause some minor shorts between the windings. (If the shorts are major it won't turn at all and will trip a breaker.) In this case the motor can be rewound, but it will probably be cheaper and easier to just replace the motor.
Good luck, Al K
Posted on Oct 22, 2010
The blade tilt mechanism is very hard to move. Hard to turn wheel to adjust the cutting angle between 90*and 45*. how do I fix this?
Usually this is due to debris in the trunion or gear set. Take some time to clean it all out, then use a small amt of oil to lube ways and gears.
Nov 15, 2014 | Saws
I have a delta 34-444 table saw, is it a right or left tilt, or how do i find out?
Left-tilt, right-tilt refers to the direction the top of the blade can be tilted when it is not straight up and down. There will be an indicator on the front of the saw, normally pointing to zero. When you adjust the blade away from zero, if it tilts to the left, it is a left-tilt saw.
Feb 05, 2013 | Delta Machinery Delta 34-555 Sliding Table...
28-276 Delta bandsaw blade keeps coming off?
Unplug the machine, gain access to the two wheels. On the back of the machine you should have a tilt adjustment knob. Manually turn the wheels in the direction of the cut and at the same turn adjust the tilt knob on the back of the machine. This should solve the problem.
Sep 27, 2010 | Delta 28 168 Bench Band Saw Blade 56 1/8...
I jsut bought a used Delta 28-682 18" bandsaw. I am shocked by the poor quality of the blade guides. They are gapped so far apart that they hardly touch the blade unless it is twisted at a 45 degree...
It sounds as though the friction pads that go on the guides are missing. If you cannot buy a new set, try glueing some teflon blocks of the desired thickness to the guides.
Apr 06, 2010 | Delta 28 682 18" Steel Frame Band Saw
Cutting 45's on my Dewalt 744
Narrow throat plate should work. Sure you have the blade installed correctly with arbor washers?
Feb 28, 2010 | Dewalt DW744S 10" Portable Table Saw with...
How to cut compound miter on a flat surface, where can I find the chart.
It's a combination of an angled mark on the board and the bevel on the saw set to the proper angle. What are you trying to cut?
Jan 28, 2010 | Delta Saws
Craftsman model 708100 table saw tilt lock won't stay locked
Dec 11, 2009 | Craftsman 10" Table Saw
Older Delta 10'' Miter Saw Zero setting is out by 1/2 degree.
Undid the RH fence-bolt in the table behind the fence and tapped the end of the fence forward to make it perpendicular to the blade. Tighten bolt. When you look down on the two fence bolt heads, one is easy to rotate with a socket wrench, the LH bolt head would be very, very difficult to move. Undo the RH bolt to swing the fence angle WRT the blade.
Apr 08, 2009 | Delta Saws
Grinder problem
* The base plate can be tilted to make angled cuts. Most saws adjust from 90 degrees to slightly less than 45 degrees, making it possible to cut bevelled ends on boards for corning attachments, hip-roof rafter cuts, and even miters. Most saws are equipped with a thumbscrew or lever to loosen the bolt which keeps the saw blade on the correct angle for the cut you are making, located on the front of the saw. Some are also equipped with a scale which indicates the blade angle, from '0' (90 degrees, or square to the board surface) to 45 degrees. * The blade can be set to the depth required for individual cuts, from less than 1/8 inch to the full depth the blade is capable of penetrating. The lever or thumbscrew which locks the base plate at the desired height is usually located at the rear of the motor on the left side. * Many circular saws are equipped with a ripping fence, to guide the blade as you make a rip cut along the edge of a board, giving you a straighter, parallel cut. * Dust ejector. A few newer saws are equipped with a dust ejector to blow the sawdust away from the operator's face and from the mark where the cut is being made. * Laser tracking light. Some newer saws are equipped with a laser that projects a bright, red line down the path of the blade travel. These can also be purchased to retrofit on older units that are not factory equipped with them. * Blade guard. This should be considered a essential safety feature on any saw, and has two parts, the fixed guard over the top of the blade, and the floating guard, which rolls out of the way as the saw is pushed into the work piece. Some have a handle so the blade guard can manually be lifted for plunge cutting or easier viewing of the cutting mark.
Aug 27, 2008 | Speed CGW ABRASIVES 35587 "24-GRIT" HIGH...
Saws Logo
75 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
