Question about Irons
My Rowenta commercial Steamer does not want to even turn on, no light , and there does not appear to be a problem with the cord, it is only 2 years old ? No light no power no steam, no nothing , DEAD?
My Rowenta commercial Steamer does not want to even turn on, no light , and there does not appear to be a problem with the cord, it is only 2 years old ? No light no power no steam, no nothing , DEAD? what can the problem be . The electrical wall outlet is active...
    Master:
  • Irons Master
  • 996 Answers
Check mains wire & plug
Posted on Jan 21, 2015
DiYerTech
  • 70 Answers
SOURCE: steam from rowenta preassure iron and steamer
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
Posted on Jul 02, 2008
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
SOURCE: My Rowenta Garment Steamer will not steam up.
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
Posted on Apr 10, 2009
  • 258 Answers
SOURCE: I have the IS7500 verticle steamer by Rowenta.It
sounds like the level of the water is below pick up tube u should be able to re adjust the pick up tube
Posted on Feb 12, 2010
  • 159 Answers
SOURCE: Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
Posted on May 19, 2010
Were can i take my rowenta steamer for repair in the 90035 los angeles area
Anaheim, Berkley, Fresno, Bakersfield, Los Angeles,
Long Beach, Sacramento, San Diego, San Jose and San Francisco.
Google Rowenta repair Center, choose a city and go!
Jul 24, 2014 | Rowenta Commercial Garment Steamer - White
Rowenta garment steamer is 9100 lights up but no steam
Look at the manual again maybe theres a button that you have to turn on. Or call the nearest repair man maybe he knows or can tell you.
Dec 26, 2012 | Rowenta Commercial Garment Steamer - White
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
My rowenta steamer has stopped steaming, it's a is6100, Ive had it for about 2 years.. I have rinsed out the bottom where the water tank connects with the bottom. I've noticed several black particules...
Having the same issue, if you have found a solution short of buying a new one, please share it...I am thinking surely there is a reset button but have not found it yet.
Jan 31, 2011 | Rowenta Commercial Garment Steamer - White
May 19, 2010 | Rowenta Commercial Garment Steamer - White
Rowenta commercial steamer
CLEANING
to water and use.
descale.
water.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Irons Logo
189 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
