Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washing machine feels unbalance, loose, and licks water.
I have a whirlpool quitewash top loader washing machine. i wanted to know if i could do something to fix it or do i have to buy another one.
    Champion:
  • 249 Answers
Posted on Dec 01, 2007
My whirlpool wtw4950xw2 top loader washing machine sounds like a jet taking off during spin cycle ... How can I fix it ?
You can unbalance the load more to get a quieter spin, but otherwise you may have a worn out gear system that produces more noise than the spinning tub itself. Check with service to determine the exact cause of the noise.
Feb 01, 2015 | Whirlpool WTW4950XW Top Load Washers
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
What would you recommend for a good super capacity top loader washer? My 15 year old Whirlpool just died. Don't really trust electronic controls, reviews of he top loaders are so mixed, I am unsure. Also...
To be honest I really don't trust electronic controls due to the fact that the majority of the repairs i do on front loader machines has to do with the electronic controls. In my opinion top loaders are more reliable. they get the job done. If you were to get a top loader i do recommend whirlpool, even though i agree that the quality is down. I also like the whirlpool cabrio, its a top loader but has electronic controls. it uses less water and soap just like a front loader. Whatever you do decide to purchase, I highly recommend that you purchase the extended warranty. This way if there is ever a problem, you know that you are covered.
Feb 03, 2011 | Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
I have a top loader and i have been getting an LL error
I would next check the TDS. Are you taking the error in Spin Cycle of the wash cycle?
Let’s do this quick check and see what you get for test results.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
What are your results?
Rich
Mar 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lot of noise in last spin and lick water when spining
make sure tub top seal is snapped all the way around, if loose in spin cycle will through water over top
Sep 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
I have a Whirlpool Cabrio top loader. My wife is going crazy with the unbalance of the unit everytime she puts in sheets. They ball up and the system shuts down with code of ul. She then has to open the...
call servce possible issue with control board program problem senses off balance too easy.. also supposedly there is a redesigned wash plate that helps
Apr 25, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
