Question about Garden
How do I find an inline fuse for a mtd ranch king 38inch 14hp riding mower
Mtd ranch king model
    Habit-Forming:
    New Friend:
  • 26 Answers
It should be under the cover right between your legs when you are sitting on the mower
Posted on Nov 20, 2014
  • 109 Answers
SOURCE: mtd riding mower model 13AT688H731 B&S 21HP
Did you change the voltage regulator???
Posted on Apr 24, 2009
  • 636 Answers
SOURCE: mtd ranch king lawn mower drive belt
Try this site it is called manuals online, should be able download a manual for it for free, also for future reference would be nice.
Posted on Jul 11, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
  • 33 Answers
SOURCE: MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Posted on Apr 14, 2010
SOURCE: MTD RIDE ON LAWN MOWER SOLENOID
CHANGE DRIVE BELTS
Posted on Nov 09, 2010
MTD RANCH KING RIDING MOWER TURN KEY AND JUST CLICKING NOISE. DID PUT NEW SOLENOID TWO YEAR AGO. OLDER MODEL RANCH KING.RAN AT END OF GRASS YEAR BUT NOW JUST CLICKS ????
make sure all terminals are clean & tight on all + & - from battry to starter check that terminals are snug on ends of cables if still clicks put screw driver across selenoid with switch on from hot cable to hot cable both should be red you mite get a little spark thats ok should start if so cut off & try w/key sometimes switch or regulator will cause same problem sometimes they will keep starting with key
Feb 12, 2015 | Mtd Garden
How do you find an inline fuse for a mtd 38inch 14hp riding mower the model number is d01338cn. i hope that is it the tag is very very faded
trace positive wire from battery to solenoid and then to ignition switch fuse should in between
Nov 16, 2014 | Garden
How do you find an inline fuse for a mtd riding mower 38 inch cut 14 horsepower
Start at the ignition switch and look for the starter wire..it should be the one tat is slightly heavier and normally red..and goes to the solenoid pos side..good lu k
Nov 16, 2014 | Mtd Garden
How do you find an inline fuse for a mtd brand riding mower 38inch cut 14 horsepower?
Lift the hood and it should be close to the front side that you are now looking into. Look for the new flat colored fuses not he round old style fuses.
How do I find an inline fuss on a mtd ranch king 38 in 14hp riding mower8
Lift your hood and look around where your ignition is. Not sure on this model but that's where I would start. Some are regular car type fuses plugged into the wire. Sometimes there is a fuse block with multiple fuses like on a Toro. You should see it around there though. Good luck.
Nov 15, 2014 | Mtd Garden
I want a drive belt diagram for a ranch king pro riding mower?
It's easier to find the correct information with a model number.
I have found a owners manual listed under MTD 130-390A
owners manual for a 2002 ranch king riding lawn mower.
Hopefully this is the same as yours.
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=ranch%20king%20riding%20mower%20manual
Pages go right and left or click on download.
Aug 28, 2014 | Garden
Wheels for ranch king push mower 6.0 22 inch cut
Try EBAY,type in Ranch king wheels and see what pops up !
May 20, 2014 | Mtd Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Open Questions:
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
