Question about Mtd Garden
How do I find an inline fuss on a mtd ranch king 38 in 14hp riding mower8
    Problem Solver:
  • 14 Answers
Lift your hood and look around where your ignition is. Not sure on this model but that's where I would start. Some are regular car type fuses plugged into the wire. Sometimes there is a fuse block with multiple fuses like on a Toro. You should see it around there though. Good luck.
Posted on Nov 25, 2014
  • 153 Answers
SOURCE: ranch kind 16.5 horsepower riding lawnmower
A dead battery would be top of the list by far, followed by solenoid, keyswitch, wiring, starter in that order.
Posted on May 29, 2009
  • 636 Answers
SOURCE: mtd ranch king lawn mower drive belt
Try this site it is called manuals online, should be able download a manual for it for free, also for future reference would be nice.
Posted on Jul 11, 2009
lester482529
  • 226 Answers
SOURCE: Need manual 18Hp 46
go to partstree.com put in your make & model numbers.then click manuals;or go to the part your looking for ,they will show a diagram if needed hope this helps
Posted on Jul 15, 2009
SOURCE: i need a belt diagram for a ranch king king plus
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Posted on Nov 21, 2009
01fordeb
  • 1033 Answers
SOURCE: ranch king riding mower will
The starter smoking is an indication that you may have to buy a new starter because when you hold the ignition over to long it will heat up the inside and burn the coil wires inside. But I would try a battery with a higher cranking amp such as a 350 CC. It will turn the engine over faster and easier.
Posted on Apr 11, 2011
Mtd ranch king will not move with the engine off and in neutral. is there a switch to release the drive so you can move it?
is this unit one that has forward /revere in between your knees . sometimes they do not disconnect without a little wiggling of that shifter
Mar 23, 2016 | Mtd Garden
MTD RANCH KING RIDING MOWER TURN KEY AND JUST CLICKING NOISE. DID PUT NEW SOLENOID TWO YEAR AGO. OLDER MODEL RANCH KING.RAN AT END OF GRASS YEAR BUT NOW JUST CLICKS ????
make sure all terminals are clean & tight on all + & - from battry to starter check that terminals are snug on ends of cables if still clicks put screw driver across selenoid with switch on from hot cable to hot cable both should be red you mite get a little spark thats ok should start if so cut off & try w/key sometimes switch or regulator will cause same problem sometimes they will keep starting with key
Feb 12, 2015 | Mtd Garden
How do you find an inline fuse for a mtd riding mower 38 inch cut 14 horsepower
Start at the ignition switch and look for the starter wire..it should be the one tat is slightly heavier and normally red..and goes to the solenoid pos side..good lu k
Nov 16, 2014 | Mtd Garden
How do you find an inline fuse for a mtd brand riding mower 38inch cut 14 horsepower?
Lift the hood and it should be close to the front side that you are now looking into. Look for the new flat colored fuses not he round old style fuses.
How do I find an inline fuse for a mtd ranch king 38inch 14hp riding mower
it should be under the cover right between your legs when you are sitting on the mower
Nov 15, 2014 | Garden
I want a drive belt diagram for a ranch king pro riding mower?
It's easier to find the correct information with a model number.
I have found a owners manual listed under MTD 130-390A
owners manual for a 2002 ranch king riding lawn mower.
Hopefully this is the same as yours.
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=ranch%20king%20riding%20mower%20manual
Pages go right and left or click on download.
Aug 28, 2014 | Garden
Need a wiring diagram for ranch king?
Go to MTD website and download the manual for your machine.
Jun 15, 2014 | Mtd Garden
Wheels for ranch king push mower 6.0 22 inch cut
Try EBAY,type in Ranch king wheels and see what pops up !
May 20, 2014 | Mtd Garden
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
