Want to hook up my 5.1 to stereo source
No longer have 5.1 computer
  • 55 Answers
You will only be able to connect the 2 front speakers
Posted on Nov 25, 2014
How do i get the external audio output to work?
First make sure that your TV has an audio OUT. Most do not. If you do then you can plug into that but you will have to go into the menu on the TV under audio and turn on the external speaker feature. If you do not have an audio OUT then you will have to hook you speaker to the audio OUT of your home stereo system and hook the source output to the input of your stereo. Source being (dvd, cable box). In that case you need to turn off the internal speakers on the TV and just run it through your home stereo system.
Mar 07, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
I connect the acc wire to 12 volt and stereo stays on all the time
The accessory wire is suppose to be hooked up to your ignition wire and not a constant 12 volt power source. Hooking it up to your ignition wire will only give the stereo power when your key is in the accessory position or in the running position. The constant power source that you mostly connected to is meant for the memory wire on your stereo which will allows it to save your setting when you turn the vehicle off and your stereo kicks off. Otherwise you will end up setting the clock and adjusting your EQ every time you turn it on.
Feb 22, 2014 | 2004 Pontiac Sunfire
Cant figure out how to hook them up
Two audio input cables are supplied with the speakers. If your computer has a stereo mini jack, use the cable with a stereo mini plug. Otherwise, use the cable with RCA plugs on both ends. Match the colors on the connectors to the colors on the jacks, red to red and white to white.
The speaker cable is already attached at one end to the accessory speaker. Plug the other end into the TO ACCESSORY SPEAKER jack on the powered speaker.
1. Connect one end of the audio input cable to AUDIO INPUTS A. 2. Connect the other end to your computer's AUDIO OUTPUT jack. We recommend using LINE OUT if your computer sound card offers more than one option. 3. To connect a separate CD-ROM, or another source, repeat steps 1 and 2 using AUDIO INPUTS B.
You must connect the AC power pack to operate the speakers. 1. Plug its cable end into the power jack on the powered speaker. 2. Plug the power pack blades into the wall outlet. 3. Turn on your computer sound source or external sound source.
Jun 27, 2011 | Bose MediaMate Computer Speakers
How do you hook up an mp3 player to insignia ns-r2000
You will need an Dual RCA to 3.5mm stereo cable. One similar to this: http://www.dcables.net/Dual-RCA-to-3_5-mm-Stereo-Cable-5-Feet.aspx
It would probably be easier to pick one up at your local Wal-Mart or Radio Shack.
Just connect the RCA connectors to one of the audio line inputs and the 3.5mm to your mp3 player. Set your insignia to receive the source you just connected.
Hope this helps
Apr 07, 2011 | Insignia NS-R2000
Is there any way i can use all channels regardless of source? i would like to understand what i need have as an input source inorder to use all 5.1 or at least 4 speakers
The answer is yes - and no. By definition, audio sources are encoded or recorded in a specific manner. If I record a stereo signal, there really are no rear channels or center or bass specific channels. To be most faithful to the original, you play back stereo in stereo and 5:1 in 5:1 and so on. There ARE several units designed to "synthesize" additional channels from sources that do not contain all the info specifically. Some multi-channel receivers/amps incorporate such circuits and you can "derive" rear channels from stereo inputs and so forth. If not, you may need an additional box (device) to turn 2 into 4 or 5, 3 from 2 and so on. Your choice but that's how it works.
Oct 22, 2010 | Yamaha HTR-6130 Receiver
Hooking up stereo to the 32". I have a Sattellite box, DVD and stereo to hook up everything works but now there is no where for the audio out that I can get to work.
Your best bet for audio is connect the audio directly from each source to the stereo amplifier. Some lower end model TV's do away will the extra inputs and outputs.
May 18, 2010 | Dynex DX-L32-10A 32" LCD HDTV
How to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Jan 07, 2009 | Bose 901 VI Main / Stereo Speaker
My JVC KD-S25 will only turn on when I press the eject button, and then it shuts off in 5 seconds.
I just bought this stereo and installed it the other day. I had the same issue. Hook the Yellow power wire and the red accessory power wire to the same power source. That solved my problem.
Oct 11, 2008 | JVC Car Audio & Video
JVC AV27D305
Get an outside audio source such as a home theatre or any stereo and go from the red and wht audio output to the input on the stereo.You could also use computer speakers just make sure you get a minijack to rca cable like the ones used for hooking up ipods to stereos.Computer speakers are very inexpensive and sound better then TV speakers.I hope this helps
Sep 25, 2007 | JVC AV-27D305 27" TV
44 people viewed this question
 Grubhead
Grubhead
