Question about Arris DCT6200 DTV Receiver
How to get time displayed back on my Dvr box after being unplugged
When my DVR Box got unplugged accidently Thje time is not displayed on the box everything else is workin, How do I get the time back on it
  • Official Brand Answer
  • 3,100 Answers
Carolynn's
Contac Arris
ARRIS for Consumers
Mark
Motorola Mobility Support
Posted on Nov 18, 2014
  • 15 Answers
SOURCE: DCT6412 DVR Box
When that happens its most likley you had a power outage and the box reset.  Well kinda reset but not all the way.  You can unplug the power and wait about 10sec and plug it back in and wait a few min to a few hours, and If that doesn't work get a new box.
Posted on Oct 18, 2008
SOURCE: Motorola DCT6412 Cable box
Ive seen this before...that may be indicative of an upgrade of the software in the cable box that comes from your cable provider. The best thing to do is plug it back in, let it get the "yellow ring" for a bit, and wait for the upgrade (it make take 10 - 15 minutes). Then things should return to normal... If the condition persists, try to call the cable company.
Posted on Feb 05, 2009
SOURCE: archos dvr station remote control
It sounds simple, but the archos must be facing the sky+ box. I spent hours messing around with archos support and qvc and in the end it was simple. I put the archos 6" away from the sky+ box, facing it, selected thomson, in the loist of sat receivers and it was code 15 of 16, good luck.
Adrian
Posted on Feb 11, 2009
  • 71 Answers
SOURCE: dvr stuck on ''receiving satellite info'' when reset.
When it's rebooting, on the first blue screen press 02468 on the remote. This will force a software update. If you have trouble getting it enter at the right time or you just want to make sure, just keep pressing 02468 until it goes to the update. It won't hurt any thing. Hope this helps.
Posted on Mar 18, 2009
SOURCE: Help!
Unplug the unit> Remove> Take out to back yard> Smash repeatedly with a sledge hammer of at least 2Lbs> Mail the resulting material to cable company preferably next-day.
Posted on Jun 03, 2009
Front power indicator blinks, clicking/high pitch sound
  1. This how to is to repair hard drive, software and some firmware issues that can arise on specific cable DVR and DAC and DCT boxes, First instructions are for Scientific Atlanta hardware. Firstly, one should be certain that the cable box has the coax (cable antenna wire) hooked up to the CABLE IN or RF IN on the box itself and be connected to a "hot" outlet - one that you KNOW works. Test it by connecting a TV directly to outlet. If you get a weak signal, the box will too. Digital boxes require a clean SNR. Remove in-line "surge protectors" on the coax. These prevent the signal from being sent by your cable provider to your box.
  2. Scientific Atlanta DVR or High Def boxes:These need to be "booted" or reset when certain errors occur. No audio on certain channels when SAP is NOT set to ON and confounding error codes that one can't seem to get out of. Common yet confounding errors are : No Audio on DVR Playback. No Audio on Certain Various Channels (ruling out SAP which can be enabled through the box, OR the television set itself) there are easy ways to test. If some channels audio is in Spanish when they are normally in English...the obviously you will check SAP first.
  3. Disc errors. On screen error on your TV that says something like..."there are problems with your storage disc.." or upon DVR playback instead of playing your program it loops upon itself and plays nothing.
  4. two different steps to reboot box: Simultaneously press VOL+ VOL- and "INFO" buttons on box itself, not from remote. Box will then display "bOOt" and shut down totally. Do not press ANY buttons or try to power on said box. Wait for the correct time to display on the box. This process can take anytime from 40 seconds to hours, depending on how fast the cable company's servers are responding at that moment and whether or not you have enough of a cable signal to fire up the download process. If you call customer service for your provider if this does not work, most likely a truck roll will be run for a tech to come out to your residence to fix the signal issue.
  5. When the correct time display is on the Scientific Atlanta box, THEN power on box and problems should be solved. An alternate way to reboot box is to simply unplug unit from power supply and replugging it in. Simply powering it on and off with the POWER ON button will not solve anything.
  6. On a Motorola box and/or DVR, the easy VOL+ VOL- and INFO will not work to reboot. Remove AC power plug from wall socket and wait 30 seconds to a minute while box is powered ON. Plug back in to wall socket.Box will "do it's own thing" and power itself on on it's own after the cycle has been successful (30 - 60 seconds) and the box should power itself back to the ON without you doing anything. Time will not display on Motorola"General Instrument boxes unless you set it up to do so in the settings mode.
  7. Common IControl/On Demand errors:
  8. MOTOROLA BOX Error 225 : A billing lock to prevent you from ordering pay per views. If your account is past due, or if you have an order to move to a new address in the service provider's "system", this is a preventive measure to keep customers from loading up tons of expensive pay per views and skipping out. Your cable company cannot over-ride this error. If you are not in above situations, your provider can "up" the limit on the box and clear it so you can order PPV through your remote control.
  9. SCIENTIFIC ATLANTA: for above mentioned error code, your SA box will display not a code but a prompt to contact your provider by telephone. Same issue.
  10. MOTOROLA BOX ERRORS 204...203.. 207..these may be easily solved by simply reseating the coax and then rebooting box.
  11. SCIENTIFIC ATLANTA ERRORS 2207: reboot box. This is a general code meaning the box has lost contact with the server. All of your iControl /On Demand orders come through your local cable head-end's servers. If and when it gets overloaded and times out, error 2207/207 will happen. Most of the time this is temporary. Reboot box, try again in 15-20 minutes.
  12. DVR BOX not displaying/recording/playing items:
  13. Reboot. Good chance of fixing.
  14. If your TV displays "One Moment, Please. Your Channel Should Be Available Shortly..." this is a SIGNAL issue. Reseat the line running from wall to the CABLE/RF IN on the box and at the outlet at wall. If no joy, call cable operator.
Nov 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
LED TV takes 7-13 mins to display a picture when hooked up to cable DVR box, when hooked up w/ out DVR Does Not do that???
I would suggest you verify your cabling. Are you using HDMI cables? Connect a HDMI cable from the TV HDMI 1 to the Cable DVR Box, In the TV setup ,select HDMI 1 as source. If your Cable box does not have HDMI contact the provider for a updated box. With out the Make, Model of Box, Cable? Sat? Make, Model of TV. I don't know the connections?
Jan 26, 2013 | Televison & Video
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Connecting my new DVR
i dont know what kind of dvr you have, but mine has component terminals to plug my cable box in, and out plugs that go to the tv.
Dec 31, 2009 | Audio Players & Recorders
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Help!
Apr 24, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Arris DCT6200 DTV Receiver Logo
82 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
