Question about Music
I have a pignose amp with a blue wire that I don't know where it goes.
  • 28 Answers
If you can upload photos of the wire and the board of the pignose maybe I can help.
Thanks
Posted on Nov 26, 2014
2 Suggested Answers
  • 5603 Answers
SOURCE: wiring diagram pignose 7-100 guitar amp which
There are a couple thumbnail sketches of the diagram at:
http://music-electronics-forum.com/t8790/
They are down about 3 an 6 of the blogs.
Posted on Nov 30, 2010
Which wire yellow or blue goes on red post
Peavey color indicates that Blue is Negative And Yellow Is Positive, so Yellow goes to + Speaker Terminal.
Feb 03, 2012 | Peavey SP2 PA Passive Speaker
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
My crown Itech 4000 left channel is phasing in and out. Could it be a collection of dust problem?
It is POSSIBLE that it could be a collection of dust problem however my guess would be on a loose wire being vibrated by the sound from a nearby speaker.
I would
  1. Clean all dust you see off
  2. Test and see if problem is corrected
  3. If it isnt check to see if there are any loose wires.
  4. If there are no loose wires. Let me know.
May 07, 2011 | Crown iTech-8000 Power Amp (Certified...
I have a older dimarzio paf i think its a fred ?with one bare wire a red and a white i need a diagram to put in a strat at bridge
I don't know about this specifically, but my general advice is to use the Dimarzio site and forums for info. The bare wire will be ground/earth and the red is hot. It simply goes to here the original one went in the guitar.
May 01, 2011 | Dean Guitars ingle Coil Pickups, Classic
Wiring diagram pignose 7-100 guitar amp which wire goes where?
Nov 29, 2010 | Marshall Amplification Marshall Mini Stack...
Looking at what I think is a magnavox speaker. basket has these #s P-232 914 p meaning alnico, 232 meaning magnavox. it also has 1D3309 and has 472 6 on the cone. What do these mean? Is it a bass or full...
A 5 watt guitar amp is puny. A decent size speaker would be a minimum of 10 inches diameter. A minimal guitar amp (except for the PigNOse type) would be at least 15 watts.
Try the speaker... It is unlikely you can get much data on the speaker as it may have been made special for the organ it came from. The other numbers are probably production run numbers.
Mar 17, 2010 | Music
Mackie 1604 Power Connector orientation
Here's a shot of the connector, mated to the motherboard.
Mar 27, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Music Logo
60 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
