Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have an AF code on my Maytag Bravos dryer. However, the exhaust tubing is totally clear all the way out to the outside vent and there is excellent airflow coming out of the outside vent. Also the li
I have an AF code on my Maytag Bravos dryer. However, the exhaust tubing is totally clear all the way out to the outside vent and there is excellent airflow coming out of the outside vent. Also the lint screen is clean. So what's the problem?
  • Maytag Master
  • 2,694 Answers
You can pull off the vent line from the back of dryer and run it,if it runs correctly you have a block in the vent line,i use a leaf blower to blow out the line.the dryer should be pulled aprt and cleaned out once a year,if the dryer still shows the code i changed the thermistor and this took care of the problem.you should run it in diagnostics to make sure to see what the problem is,there's a tech sheet on the machine could be in the top console or taped to the back of bottom panel depending on your model number,also if you use cling free sheets you can remove the thermistor and clean the back of it,i've found the white powder from the sheets stuck to the back,i cleaned it off with a tooth brush and it worked but i still changed it out.hope this helps and good luck.and unplug the dryer before you touch it.
Posted on Nov 16, 2014
    New Friend:
    Problem Solver:
  • 20 Answers
I would do a Puddle test on the Lint Screen. A Puddle Test is pour a handful of water onto the Lint Screen. If it Puddles Wash it out with Dish Soap and rinse with Hot Water, See we use Fabric Softener Sheets the Oils from the Sheets clog the little tiny holes an it's hard for the air to flow thru it, This should be done every 6 Months just maybe it's giving it a False reading, also maybe check the Door Gasket
3 Suggested Answers
SOURCE: AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Posted on Mar 18, 2010
Testimonial: "Thanks so much!"
machinetech7
  • 1344 Answers
SOURCE: maytag gas dryer bravos mod#MGD6400TB0 no heat
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct
Posted on May 12, 2012
Have a minimax nt LN heater that won't ignite.. I am getting an E04
possible bad fenwal not letting gas valve open see if ignitor is glowing if not check high limits
Mar 17, 2017 | Pool & Spa
VGA TO VGA CABLE
The VGA connector on the laptop is for an external screen, I would'nt connect 2 laptops together like that.
Jan 31, 2012 | Acer Aspire 5516-5063 Notebook
An orange light apear's on the power bottom and a loud fan noise
hope you did'nt drop it but if you did'nt turn off unplug take cover off see if motor or fan is tight if it is could just use a good cleaning take a can of air they sell them everyware give it a good cleanning this should solve your issue.
Jul 28, 2011 | Dell OptiPlex SX280 PC Desktop
How do I clean or replace the covers that cover the headlights?
they sell kits for restoring/cleaning lense.just a polish material sold at most parts houses
works good & removal is'nt nessasary.may look like its on the inside of the lense but is'nt on most
Jun 29, 2011 | 2004 Pontiac Grand Prix
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me a procedure how can I clean my ViewSonic LCD Monitor screen.
To clean the monitor first turn it off then use something like a microfiber cloth or something that is not abrasive to clean the surface. Don't press down excessively this can cause damage to the monitor. If that does'nt get all the fingerprints and such off a solution of distilled water with a little
white vinegar will do fine just use it lightly and don't drown the monitor. Make sure to use just enough solution to lightly dampen the monitor and not so much as to run down the monitor and
risk getting inside where the circuits are.
May 20, 2011 | ViewSonic VE510b (Black) 15" LCD Monitor
VERY HOT
Check the dryer exhaust piping for any obstructions or kinks
Check the exhaust blower
Make sure the lint screen is clean
Make sure the dryer isn't overloaded
Jul 03, 2009 | Maytag PYE4558A Electric Dryer
Maps don't show after downloading upgrade.
sounds like you might not have the new map set selected
settings -> map -> map info (make sure the NT 2009 map is checked)
Mar 17, 2009 | Garmin nuvi 350 GPS Receiver
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
947 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
