Question about Cameras
Any one there able to help? URGENTLY NEEDED SERVICE (REPAIR) MANUAL FOR PANASONIC LUMIX LF-1
Help. I have a problem with my Panasonic Lumix LF1. After dropping it on the ground Zoom only zooms up to 70mm than retracts automatically reporting " System Error (zoom)" This fix is not covered by the Lumix Warranty. Service/repair price would exceed the price of the almost new camera. The zoom does not seam stuck. It retracts completely. Resumes when stitching on etc. It looks like the lens system is misaligned. I took the camera apart and everything looks ok. Everyting seems to function. Only the auto focus/ zoom synchronization is out. Reset did not help. Removing battery for 48 hour did not help either. Thanks Peter
    Top Expert:
  • Cameras Master
  • 6,702 Answers
It won't be easy to get a repair manual. But I advice to visit ifixit, to see if they have a manual or video for your camera. They also can help with spare parts. Camera Repair
Posted on Nov 26, 2014
  • 11967 Answers
SOURCE: Panasonic Lumix dropped
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
Testimonial: "Thanks so much on the advice on the dropped Panasonic Lumix camera! I went straight to number 7 and twisted the zoom, worked wonders!! thanks a lot!:)"
  • 18 Answers
SOURCE: panasonic lumix dmc-fx37. Two error messages are
sounds like the focus and (Optical Image Stabilization)drive motors are bound or broken, sadly this normaly means new camera, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well ya know, they will normaly repair or replace it as long as it is due to manufacture defect.
Posted on Mar 16, 2010
Testimonial: "thanks for your help. "
lock123
  • 6831 Answers
SOURCE: system error (zoom) camera frozen Panasonic Lumix DMC-LZ28
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
lock123
  • 6831 Answers
SOURCE: System error: zoom message with Panasonic Lumix FS15 camera
Hello
Regards
Andrea
Posted on Oct 12, 2010
I had the same problem, i switched the camera on in capture mode and zoomed in and applied a little pressure to the lens which made a slight click but retracted and has worked fine since. I may of just been lucky but the camera is fully functional again, could be worth a try.
Posted on May 20, 2011
I have a LUMIX FZ28 and the controls do not respond. Any idea of what could be wrong? The camera has an internal battery?
Operating Instructions - Panasonic
service.us.panasonic.com/.../DMCFZ28.PDF Panasonic CorporationFor Canadian assistance, please call: 1-800-99-LUMIX (1-800-995-8649) or send e-mail to: ... retain this manual as your convenient Camera information source.
Jul 11, 2015 | Panasonic Lumix DMC-FZ20 Digital Camera
I want a manual of panasonic lumix DMC-TZ7 in
Go to the support section of the Panasonic web site to download a copy.
Dec 07, 2009 | Panasonic Lumix DMC-ZS3 Digital Camera
No, I am trying to download a copy of an owner's manual for my Panasonic Lumix TZ5 camera.
Here is your manual: You may need adobe acrobat or foxit reader for firefox to read it.
[PDF] DMC-TZ5 DMC-TZ4File Format: PDF/Adobe Acrobat
For Canadian assistance, please call: 1-800-99-LUMIX (1-800-995-8649) or .... Example screens displayed in this manual are for DMC-TZ5 model. DMC-TZ4: ...... MAIL THIS ORDER TO: PANASONIC SERVICE AND TECHNOLOGY COMPANY ...
service.us.panasonic.com/OPERMANPDF/DMCTZ4.PDF - Similar pages -
May 10, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
Lumix FX9
Fed up with the zero response from Lumix, Panasonic and Matsushita I came up with my own solution.......I bought a Canon Digital as replacement. 9 Mega Pixels, 4 times digital zoom and 20% approx. of the price I paid for the heap - of - **** Lumix.
Bye- bye Lumix, Pana and Matsu....you wont be seeing me as a customer again.
Feb 20, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Cameras Logo
88 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
