Hi,our hotpoint wdal8640 is showing all the program lights flashing,it fills up with water then starts to empty and then it carries on filling to the point i cannot turn it off only by switching it of
Hi,our hotpoint wdal8640 is showing all the program lights flashing,it fills up with water then starts to empty and then it carries on filling to the point i cannot turn it off only by switching it off at the plug,iv checked all the hoses and wires and im sure somethings gone on it but am not sure,can anyone giv me any clues to the problem???
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: My Hotpoint machine has filled with water and
Error F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Posted on Jan 30, 2010
  • 215 Answers
SOURCE: Hotpoint BWD 129 machine starts to fill -
Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
Posted on Feb 12, 2010
SOURCE: Hi my hotpoint wma63 fills with water for a wash, then empties
motor tacho not being sensored...motor or pcb fault...chopper board faulty bottom front right in machine.
Posted on Oct 15, 2010
caroldon
  • 17130 Answers
SOURCE: Hotpoint H2O error
Please check on the water flow to the drum, if the flow is low or if the inlet is choked the water flow in the set time limit can be low and so could trip.
secondly it can be due to problems in the level sensor, try and see if the pressure switch works outside.
Finally check on the program controller unit once again to see the triping. check the door switch for loose connection.
check this link for tips:Washing machine
Posted on Jun 26, 2012
Hotpoint aq7L149i washing machine flashing lights ?
Hi Jason.
The most likely reason for your problem is that the water inlet valve is faulty. This is why the machine won't fill.
It is a simple fix for a serviceman.
Good luck.
Nomess
Nov 21, 2014 | Hotpoint Washing Machines
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Jul 31, 2010 | Hotpoint Washing Machines
Feb 12, 2010 | Washing Machines
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
