I have a circa 1940s royal typewriter. Bought it from a professional online who claimed it worked, everything looks good but the carriage and ribbon will not move. Tried messing with the margin buttons but still wont move. Help please!!!
  • 27 Answers
Sometimes they had a carriage lock for transporting it. Check for a little lift up lever thingy at the base of the carriage on the bar that goes across from one side to the other. Or just check around for any little levers that hold the carriage in place.
Cheers
Posted on Nov 18, 2014
4 Suggested Answers
SOURCE: need free downloadable manual for swintec 8014 s typewriter
reset daisey wheel on tandy word processor
Posted on Aug 10, 2011
JayBlair
  • 328 Answers
SOURCE: Olivetti Lettera 32 typwritter carriage will not move?
There is a lever in front of the right knob that is used to lock the carriage.
Posted on Sep 07, 2009
  • 46 Answers
SOURCE: resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Posted on Jun 26, 2009
I have a manual desktop circa 1940s royal typewriter. Bought it from a professional online who claimed it worked, everything looks good but the carriage and ribbon will not move. Tried messing with the...
most royal portables have a locking lever to lock the carriage in the center position try looking on the right side near the lower edge of the carriage
Nov 16, 2014 | Office Equipment & Supplies
Royal typewriter drive belt
The belts are no longer made but if you have a good hardware store (not a big box store) you can get a long "O" ring that will work. The ribbons are pretty common I have them in stock.
DickyO
216-269-3918
Jun 30, 2014 | Office Equipment & Supplies
I bought a Royal KMM typewriter today (1940s) and it was working fine. I was looking at how to remove the ribbon and now the keys appear to be locked - they won't go up further than halfway. Any...
Look inside to see if any of the metal keys is not level with the others. Sometimes two key rods will go up at the same time and lock together. Otherwise, there is a sort of "stem" that holds the the bottoms of the metal keys in position. You might try cleaning out any debris and putting on a small amount of sewing machine oil.
Oct 29, 2013 | Royal Office Equipment & Supplies
Carriage lock on adler typewriter
Turn the T/W off, slide the carrier to the R., look for debris in the carrier area. Spray some WD40 on the silver shaft that the carrier slides on.
Move the carrier back and forth to be sure tghere isn't a bind or hitting something.
DickyO
Aug 29, 2012 | Royal ADLER Satellite 40 Typewriter TA...
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
Dec 15, 2009 | Royal Office Equipment & Supplies
The keys on the left side of my circa 1933 Royal typewriter gets stuck on the ribbon everytime. Also my ribbon doesn't advance. Help?!
Hi:
The most likely problem is there is dirt inside the ribbon basket. This is the area where the type bar (this is the bar with the actual letter on it) ends. They all fit into a semi circle area. If you can find something very narrow and thin with a hook on it you can use it to clean out the areas where each type bar goes. Then try to lightly lube the entire basket right where the type bars pivot with something light like sewing machine or 3 in 1 0il. As far as the ribbon reverse goes it might be as simple as making sure that the ribbon is being fed through the ribbon reverse forks which are usually located left of each ribbon spool.
Good luck
Andrew
Jun 28, 2009 | Royal ET510 Typewriter
I have a TA Adler-Royal Satellite 40 typewriter for my office. This morning someone was working on it and they must have done something because now when we turn it on it just keeps beeping continuously....
check the multiwire cable harness under the carriage assmbly..may have one or two broken wires close to the carriage itself...if this is the case you will probably have to have the carriage replaced.
Jun 08, 2009 | Royal Office Equipment & Supplies
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
74 people viewed this question
jasbo
jasbo
