Question about Air Tools & Compressors
Acura motor on the 2.2 CL vtec 1997 to fix
Spark plugs
    Problem Solver:
  • 7 Answers
Sorry, how to change them or where to find them?
Posted on Nov 16, 2014
1997 acura cl 2.2 vteck engine runs then dies loses power to the spark plugs then runs stays running for hours
does it stall? when does this usually happen ie: when motor is cold, humid weather or cold weather....etc
Jan 29, 2017 | 1997 Acura CL
97 acura 2.2 cl engine light p0302 code
A P0302 is indicating that cylinder # 2 is misfiring...Cylinder # 2 is the second plug counting from the front to rear of engine...Main causes for misfire are: defective spark plug, spark plug wire...When was last time plugs were changed? if it has been awhile I would suggest changing them...Also the spark plug wires should be replaced...Changing one plug and/or one wire isn't a good idea; change them all...Plugs cost two or three dollars apiece and a set of wires around $15...Standard motor products wire set # 4717...Spark plugs; Bosch platinum gaped at .044
Nov 13, 2015 | Acura Cars & Trucks
Acura 1997 cl 2.2 vtec keeps overheating even after water pump replacement
Do a system pressure test.there could be a leak in a hose or a seal.does it still want to overheat or weird changes in the temperature gauge ?
Apr 19, 2014 | 1997 Acura CL
Loses power when i accelerate
a 97 Acura Vauxhall,
is this a motor swap?
quote;
Problem with 1997 Acura CL Loses power when i accelerate
Nov 26, 2013 | 1997 Acura CL
1997 Acura CL 2.2, car cranks but will not start,does not have spark. When trying to start the D4 light will blink. Have changed fuel pump, distribitor, injector relay, computer, ignition relay under dash...
have u checked ur timing chain/belt? or even the crankshaft sensor? The crank sensor (if bad or broke) will cut out the spark to ur plugs. hope this helps
Sep 29, 2013 | 1997 Acura CL
97 Acura CL D4 light flashing
You change the transmission control molcule (TCM).
Jul 26, 2013 | 1997 Acura CL
I have a Acura 1997 CL 3.0 Vtec .
I am guessing here so be nice with your thumbs up for me please. Have you checked the transmission fluid level. Rember that when doing so the dip stick measures in pints and not quarts, Let me know. I have some other ideas too. Raz
Apr 19, 2010 | 1997 Acura CL
I have a 97 acura 2.2 cl. I want to change my spark plugs. how do i replace them seeing that they are deep in the block. tried removing the wires but kind of hard don't want to damage them. Please help.
1.Just use a spark plug range, but you must remove all the ignition wires. Put a label or number to each of the wires, so that you will put it in their proper places after you change the spark plugs.
2.Using a spark plug range will get the plugs deep in
the blocks.
3.Before you install the replacement plug, you must adjust the spark gap of the plugs to the thickness of
a hacksaw blade.
4.After installing the spark plugs, replace the ignition
wires to it's proper places.
5.then, you can get you car to start.
Nov 04, 2009 | 1997 Acura CL
CHECK ENGINE LIGHT DURING MONITOR TEST ON 1997 ACURA RL
replace the O2 sensors . Some cars have 2. At the intake and out take manifolds. they are spark plug shaped components.
Jan 16, 2009 | 1997 Acura CL
Air Tools & Compressors Logo
54 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
