Question about Video Game Consoles & Games
When can you fix my farmville2 it freezes up every few seconds or even minutes? I spend quite a bit of money on it. please fix it or I'll have to quit it cause I can't do anything on it. Thank you El
I have the latest Flash Player
    Master:
  • 388 Answers
You will have to submit a support request as it can be any reason why it would be freezing up.
Zynga Support
Posted on Dec 05, 2014
  • 3940 Answers
SOURCE: running slow.
Things you can do to speed your performance:
  1. Set your power management settings to ALWAYS ON
  2. Defragment your hard drive (Open my computer, right click C:, Properties, tools, defragment hard drive)
  3. Turn of disk indexing Open my computer, right click C:, Properties, Uncheck indexing box at bottom of page , Click OK. (Apply to all folders. You'll get an error message, click Ignore all)
  4. Right Click MY COMPUTER, Click Properties, click advanced tab, Click Settings button under PERFORMANCE, Click Adjust for best performance radio button, scroll down to botton and recheck "Use a background image ...." and "Use Drop Shadows ..." Click OK, OK
  5. As far as hardware goes, you can get a great improvement upgrading RAM. www.crucial.com, you can use the tool there to interrogate your system, then it will give you upgrade recommendations. They guarantee their RAM will work in the system and has a lifetime guarantee if it ever fails.
Posted on Sep 16, 2008
  • 3940 Answers
SOURCE: 32 bit Internet explorer freezes upon opening. But
Try IE with no add ins (Programs, Accessories, System Tools, IS with no Add ins)
If that opens, then one of the IE add ins is likely the issue.
Posted on Jan 15, 2010
proton77
  • 1183 Answers
SOURCE: it turns on for a few seconds then shuts off
Since you have already replaced the ac adapter. The problem is still there. the most likely cause of the failure is bad motherboard. Remove the battery from the laptop and disconnect the ac adapter . Press the power button for 10 seconds. Reconnect the ac adapter and try powering on the system. If the same doesnot work
Try the steps in the link
http://tinyurl.com/yd842up
Thanks for using Fixya
proton
Posted on Mar 15, 2010
destom
  • 126 Answers
SOURCE: Hello the problem with my toshiba satellite is
It sounds to me like a fan/heat issue leave it off for a while to cool down if it turns on after that and works for a while (longer than it it at the moment) you know its a temperature problem.
If it is temperature the easiest solution is to try and remove dust from the mechanisms using a vacuum cleaner or a gas gun.
If this doesn't work you might have to replace a fan
Posted on Mar 10, 2011
joegoldman
  • 335 Answers
SOURCE: usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Posted on Apr 08, 2012
My sand filter, which I just bought this summer, quit working. I turned it on, it ran for a few minutes, then quit and never came back on.
That is because it is not really a real industry rated pump/filter set up. I would not invest in same type. Spend a little extra and get a real industry rated system. You can call your local pool/spa supplier and they can hook you up with a relatively inexpensive Real pool pump & filter assembly. You will not regret it one bit! Make the move & upgrade away from that type of toy.
Sep 01, 2013 | INTEX Sand Filter Pump
2004 speed monitor indace cluster
If you experiencing issue with gauges not resetting, for example, speedometer shows speed above 120 mph while car standing still, it's quite common problem in 2004 Tahoes. You have few options:
- go to dealership and replace the cluster (a lot of money)
- search internet and find a shop to repair cluster. Since the problem is quite common, there are many options. Will cost much less then dealership
- if you are comfortable with soldering gun - buy replacement motors on Amazon, disassemble dashboard, remove cluster, replace motors. This is the cheapest option - about $35 and hour and a half of your time to replace all motors in cluster.
- last option is for people who don't like spending money (and fixing issue too), put car on emergency break, shift in gear, turn key to start engine. With every attempt gauges will reset by a bit. Repeat until gauges go all the way to zero.
Aug 02, 2012 | 2004 Chevrolet Tahoe
2003 chevy s10 - keeps blowing out AC fuse. Will work for a couple minutes then compressor quits working. Check the fuse, it is blown out. Put in a new fuse, works a couple minutes, then quits, fuse blown...
Unplug the a/c compressor, there will be a plug near the pulley. Install a new fuse. Start the vehicle and turn the a/c on. Wait about the same amount of time it took for the fuse to blow in the past. Did the cues blow? If no replace the a/c compressor, the clutch has gone bad. If yes, than the wiring between the fuse and the relay or the relay to the comps sore is grounded. A careful inspection of the wiring should reveal the problem.
Jul 03, 2011 | 2003 Chevrolet S-10
I have mitsubishi vs-45501 Projection TV and periodically the picture goes, has good sound. I let it rest for a few days and then it comes back on, then picture goes away, wait a few days and it comes...
This is quite technical because I've suspect the faulty on the ff parts :
1. Tuner
2. If Transformer
3. Leaky Electrolytic capacitor
4. eeprom
5. system IC
I've advice you to send it to the qualified service center because there will be a series of test.
It is quite fixable. First ask a quotation on the shop how much money you are going to spend on service fee plus parts because the parts above are quite expensive.
If your unit is under warranty then avail it because the manufacturer of your unit will fix it for free or a little charge only.
Thanks for using fixya.
Jan 18, 2011 | Mitsubishi VS-45501 45" TV
Even without inserting a game, my PS3 freezes after few seconds and it shuts down by itself. the console is not overheated.
PS3 keep freezes and shutdown is hardware errors : You need to repair your console. Learn the step-by-step way to fix your PS3 inner components is best way for you. I suggest a secret repair kit for you to fix the PS3 errors. This is an all-in-one style guide that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers. Learn the D.I.Y. way to fix PS3 issues can save you much money. You will receive much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light and Yellow Light Fixing Guide : http://bit.ly/fixya-ps3
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
I have a 2003 Seibring Convertible Limited (V6) (VIN 1C3EL65R93N558156) and a problems that not even chrysler has been able to diagnos! After the car warms up a bit, at all engine speeds feels like...
before you spend any more money remove and clean any ground connections yu can find, there are quite a few, my guess is that you have one that is just barely making contact and losing touch just enough that the engine vibration allows it to contact again
Sep 15, 2010 | 2003 Chrysler Sebring
I have a older hoover refrigerator and it run all the time even with the dial set to 1 the temp inside is 35 degrees
This is quite a common problem. It sounds as though the thermostat is faulty and needs replacing.
Sep 20, 2009 | Hoover Refrigerators
you have a short somewhere problably bad ground , or interferrance from alternaot overloading the circuit... check all ground securlely...if you cant locate it its not going to be cheap for a mech to locate the issue.. good luc kthough ( also check for loose wire behind the fuse box in car.
May 19, 2009 | 2003 Chevrolet S-10
30gb video has sad face and low battery and will not charge even
Don't just change the hard drive,Change the motorboard as well.Different generation ipods use different boards and the hard drive from one won't always just plug in and work.
Dec 10, 2008 | Apple iPod MA446LL/A MP3 Player
Video Game Consoles & Games Logo
51 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
