Question about Sewing Machines
Set the tension - Sewing Machines
  • Sewing Machines Master
  • 627 Answers
Set the bobbin by allowing it to hang from your finger while the thread goes under the tension. it should ride down the thread one inch when you bob it lightly. now, when this is done replace the bobbin. now, the objective is to get the top tension to equal the bobbin tension so the knot will go to the center of the fabric. this can start at a setting of three and be adjusted as necessary. the main objective is a tug of war between the top and the bottom so the knot will go to the center of the fabric.
Posted on Nov 16, 2014
Bobbin thread showing on top of quilt. how do I adjust tension?
Loosen your top tension. But, I usually have to tighten the bobbin tension too for quilting. That's why I have 2 bobbin cases. One is set for standard sewing and the other has the tension set for quilting...
Bobbin Tension How and Why Tension is Adjusted
Sep 06, 2017 | Sewing Machines
How do I determine what tension to use?
Tension setting is trial and error. To learn choose two color threads same weight and manufacture. placing one in bobbin other top tread.
Set the lower tension to light. The lower tension has always been lower than the top.
Depending on needle size and material the upper needs to be set.
Use the images as a guide.
26050009-gmetzlbygkf20izcnwtcwtjv-4-2.png Hope this helps?
Jan 12, 2016 | Sewing Machines
Serger tension is off and I can't get it adjusted properly. I have a Necchi Lock machine that is 25 years old and it's been a gem. Do you know how to adjust the tension?
Do you still have the instruction manual for the machine? If you do, you get a great big gold star!
Unless this model has auto tension, there should be a tension knob or lever on each thread feed.
Open the tensions (set at zero). No access to the tension controls, raise the presser foot and this will open the tensions, if the controls are okay.
Re-thread the serger and then set the tension controls back to mid-range or lower the presser foot to re-set the auto tension function.
With the presser foot down, stitch a chain of threads and if they do not "knit" as the should - the serger needs to visit a repair shop.
Service for a serger usually begins around $100.
It could be just the timing needs to be adjusted.
If the tension controls need new springs or the controls needs to be replaced, this will add to the repair cost.
Mar 29, 2010 | Sewing Machines
Janome ENX24.needle tension will not adjust.
Set the tension to zero and floss it with a piece of fabric or twill tape.
Re-set the tension to 4, or where you would normally set it for this machne.
Thread the machine with the presser foot up, this opens the tension contol to allow the thread to enter.
If you are still having a problem, the machine needs to go in for service.
Mar 04, 2010 | Janome Sewing Machines
Tension underside looks good, but top side the bobbin thread show
sometimes when you reset the top tension dont forget to reset the bobbin tension so try to tighten the bobbin tension
Nov 08, 2009 | Kenmore Sewing Machines
I bought a second hand Juki industrial machine , model DDL 5550-7, but struggle to get the tension of the stitches right. where do you set the lower stitches tension
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
Jul 01, 2009 | Juki MO-644D Mechanical Sewing Machine
I cannot get the tension set on my Juki TL98QE quilting machine. When I think I have the correct tension, I can sew for about 6 inches and look at bottom of fabric and it has begun looping again. The...
Is your top tension set tight? If not, it may be a problem with the tension spring and if it is a new machine will be covered under warranty. It may also be that the bottom tension is set too tight. Not a major problem
Apr 25, 2009 | Juki TL-98Q
Tension issue
If you set the tension from 3of 4 to 1 you actually lowered the tension. To increase the tension you must set the tension to 6 or higher. Be carefull not the set the bobbin case tension to tight as this will also have negative results
If suggest the following: First lower the bobbin case tension, half a turn. Then increase the top tension to 6 and see if there is any difference.
If you do this systematically you should rectify your problem.
Good Luck
Jan 21, 2008 | Kenmore 12102
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
